My Charge 6 battery depletes quickly
I was just wondering if anyone else has this problem before I go to customer support. I'm lucky if I even get three days worth of battery life on my Charge 6.
1 REPLY 1
Hi @genisi and welcome to the forums.
I appreciate your message, and I'm sorry to hear that you are experiencing this issue with your Charge 6 battery.
Please let me suggest you some steps:
Firstly, verify your phone's operating system: For more information, refer to Check & update your Android version or Update your iPhone or iPad.
Check if the Always On Display mode is turned off:
  1. Swipe down from the clock face to access quick settings.
  2. Tap the Settings app and then display settings and then Always-on display.
  3. Tap Always-on display to turn the setting on or off.
    Or, you can tap Off-hours to set the display to automatically turn off during certain hours.
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
