08-02-2024 18:18
08-02-2024 18:18
Suddenly over the last two days exercise is not being synced to MyFitnessPal. Data from MyFitnessPal is flowing to Fitbit. I have force quit the apps and revoked the access and relinked. Which kind of worked except it today over wrote my steps in Fitbit for todays!!!.but did send data to MyFitnessPal. I use iPhone latest iOS system. I need to track my exercise and macros and use both apps simultaneously. Please can I have some help
08-11-2024 06:25
08-11-2024 06:25
Just to narrow down where the syncing error is, can you sync the device to the Fitbit app ok?
Also, are both apps in question updated?
Finally, are there any firmware updates to download on either the phone or the device?
one cruise ship at a time!08-11-2024 13:00
08-11-2024 13:00
Hi
The Fitbit will sync to the app ok but it’s doing that showing same number of steps from other previous days in the app which I now know is another issue. I have 4.22 so I don’t think that’s the issue. I don’t know what the issue is i have tried reinstalling the app disconnecting from Bluetooth and forgetting and nothing seems to work. MyFitnessPal is syncing data to Fitbit ok
04-19-2025 16:59
04-19-2025 16:59
My Charge 6 connects to my app on my Samsung phone
Best Answer04-19-2025 17:14
04-19-2025 17:14
Best Answer04-19-2025 19:22
04-19-2025 19:22
Best Answer04-19-2025 21:47
04-19-2025 21:47
Best Answer04-20-2025 05:22
04-20-2025 05:22
@Saebs wrote:
You are being awesome in trying to assist.
But this is where they are driving me crazy. All my correspondence with
them has been about one the one outstanding issue.
Since the firmware update my step count on my charge 6 doesn't match
my fitbit app.
How does that have anything to do with myfitnesspal?.
My food is syncing fine from my fitness pal and the steps from the app to
myfitnesspal are syncing fine.
T*he issue is that the steps on my charge 6 and the FitBit APP do not match
*and have not since the firmware update. Fitbit Support even got me to do a
factory reset!
I am totally sick of being given the run around by them and no solution. It
is ridiculous.
It actually makes all the difference in the world if both apps aren't updated. If one app is updated and the other not, there could be compatibility issues contributing to your problem.
one cruise ship at a time!04-20-2025 06:34
04-20-2025 06:34
