06-28-2024
20:00
13:32
AndreaFitbit
06-28-2024
20:00
13:32
AndreaFitbit
I'm on a long road trip and I just noticed my charge 6 is counting thousands of steps. These are smooth highways and in a newer car. How do I get it to stop counting so many steps! It logged at least 5000 steps during this 2 hour car trip so far.
Moderator Edit: Formatting.
Best Answer06-29-2024 11:51
06-29-2024 11:51
Welcome to the community forums @Reggied111.
Thank you for providing the details about this inconvenience with your Charge 6.
Please not wrist trackers count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Unless you're driving in a car with a very stiff transmission or on bumpy roads, your device should not give you false readings. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
However, there are ways you can prevent this from happening while you drive:
1. You can plug your tracker into the charging cable while you are driving -- the Fitbit will not count steps while it is charging.
2. You can log the driving manually by following the steps in this article.
With the information provided above, please bear in mind that it's not possible to delete steps and floors, but you can achieve the same result by negating them.
Best Answer06-29-2024 19:01
06-29-2024 19:01
Like I said, it was a smooth road and new car. I was watching the steps go up on my wrist and on my phone. I wasn't moving my arms at all. The article you sent me to doesn't have very good instructions on how to log driving. Can you give me step by step instructions?
07-02-2024 23:23
07-02-2024 23:23
Log driving is easy as logging any exercise after the event.
Warning: Some users have reported that driving doesn't remover steps anymore. Sorry @ManuFitbit but when i add driving, my steps are not removed
01-06-2025 17:23
01-06-2025 17:23
Well, wth. They need to fix this! I cannot leave my watch at home while I'm driving a school bus. I need access to the correct time!
04-19-2025 12:57
04-19-2025 12:57
I wonder if things have changed in the past year. I didn't see that article mention anything about adding a driving activity.
In the Fitbit app, I click the + to add an activity, but when searching for "driving", there are no results. On the Charge 6 itself, I can only add one of the predefined activities. Seems like they did away with driving or my app or watch are missing it somehow. I just got it in December.
Best Answer04-21-2025 11:05 - edited 04-21-2025 11:06
Hello @Fitwit25
As best as I can tell, Driving was removed from the activity list in one of the app updates over the last year or so.
Please consider adding your vote & comments to this feature request: Reintroduce driving as a manual activity (<-- click link).
