New Charge 6 display is dark and no vibration after setup
ANSWERED
After the process of setting up the new fitbit and moving my account to Google, fitbit was ready to connect Charge 6 but fitbit no longer saw Charge 6. And Charge 6 had no display and no vibration. I have tried the charging cord button and the 30 sec hold for reset. Neither worked. What else should I try?
1 BEST ANSWER
Accepted Solutions
Welcome to the Fitbit Community, @Sharon_M. I'll be happy to assist with your Charge 6 set up inquiry. Thanks for letting us know that you tried restarting your tracker in order to turn it on.
Please set up your Charge 6 in order to make it work:
  1. From the Today tab  in the Fitbit app on your phone, tap the devices icon.
  2. Tap Add more devices.
  3. Choose Charge 6 and follow the on-screen instructions to continue.
If you encounter issues with your Fitbit device setup, refer to Why can't I set up my Fitbit device?
7 REPLIES 7
I connected Charge 6 to laptop via charger cable and Charge 6 woke up and I was able to finish the setup. The setup app was not aware the Charge 6 was paired so I had to verify through phone Bluetooth function app.
Thanks for getting back to us and for letting us know that you were able to finish the setup @Sharon_M.
If you have time, check out our Health & Wellness board where you can make new friends, create your own topics and find tips, as well as encouragement from other members. Happy stepping!
Your suggestion did not work. The Fitbit app could not find the Charge 6.
The Charge 6 was unresponsive.
Thanks for getting back to us and for letting me know that the Charge 6 was unresponsive @Sharon_M.
Is your Charge 6 working now?
The screen display on the fitbit no longer works.  Per the app the fitbit is active but nothing display on the fitbit.
Thanks for getting back to us and for letting me know that the screen display on your Charge 6 no longer works @Sharon_M. I'll be happy to continue assisting you.
  1. Charge the Charge 6:
    • Double-check the connection: Ensure secure connection to the charging cable and that the cable is plugged into a working USB port (computer or UL-certified wall charger).
  2. Restart the device. Your data won't be deleted. Check How do I restart my Fitbit device?
  3. Changing the clock face via the Fitbit app can sometimes resolve a black screen issue:
    • Open the Fitbit app.
    • Choose Device Settings.
    • Navigate to the clock face options and try selecting a different clock face.
