10-13-2023 17:47
10-13-2023 17:47
New Fitbit Charge 6 has swim length entry in miles, not yards or meters. Just updated to the Fitbit Charge 6 from the 5 and to the new app. Now when I manually go to enter the swim activity it only allows an entry in miles. Although I can convert yards or meters to miles this is very inconvenient.
Has anyone else seen this? Have a solution?
11-01-2023 05:46
11-01-2023 05:46
Agree: How ridiculous to have entry in miles. Google programers just don't care, absolutely no thought in this. The whole new App is rubbish! You can't now lookup proper weekly or monthly totals.
11-01-2023 05:59
11-01-2023 05:59
@4fields yes, this is a problem. I don't think anyone of Fitbit developers uses Fitbit in a daily life. One workaround is to change units to metric system, edit (in kms) and then change back. Another issue I found is that when when you swim ie. 1600m you need to enter 1.6km. Once you input a point the field will go red as invalid but you can still confirm the change and it will work. This is how I update distance because tracker never gets it right.
11-01-2023 06:30
11-01-2023 06:30
11-01-2023 06:40
11-01-2023 06:40
@Ger2000 change units only for a time of editing swim, then change back to miles.
11-01-2023 06:59 - edited 11-01-2023 07:06
11-01-2023 07:15
11-01-2023 07:15
@MattRoxx it's in the mobile app when you want to edit Swim activity recorded with tracker.
11-03-2023
09:34
10:26
ManuFitbit
11-03-2023
09:34
10:26
ManuFitbit
That looks like the older app. Here's a screenshot of the updated entry from the latest app on an Android phone. Using a Charge 6. Didn't have this issue with the Charge 5 and previous app.
Manually entering swim info. Not tracking the swim in the pool with my Fitbit. Two Fitbit Charge 5's eventually died when I used them in the pool so I just stopped bothering with using them in water.
11-04-2023 16:22 - edited 11-04-2023 16:26
@4fields Since you're using your phone, a workaround for you could be to use your phone's browser, go to www.fitbit.com and access your dashboard from the web page, which will allow you to manually enter the distance in feet, meters or miles.
11-04-2023 17:03
11-04-2023 17:03
