Do you have REMINDERS TO MOVE turned on in settings?
Go here, click on your device and then REMINDERS TO MOVE, this will expand the section and enable to enable/disable the function, you can change the days and hours you want to be notified.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Best AnswerAdding I’m in the same boat. I receive text notices to my Fitbit but reminders to move aren’t happening
when I go into the Fitbit app it seems to be automatically changing back to no on remind to move even though I click it on
I believe they didnt' take away that feature? This is for my PW1, my son's and my wife's. All the same issue.
It's been broken ever since the WOS4 update.
I sometimes get a partial vibration 10 to the hour, and if I happen to be staring at an active screen 10 to the hour I actually get the full notification. Unfortunately with AOD turned off to save battery the notification somehow gets partially blocked now.
I was hoping they'd fix it in the December feature drop but the issue is still there. Here's hoping January bug fix?
