Recurring alarm not updating
So I updated my Charge 6 this morning (on Android) now the repeating alarms are showing grey with a cross and the only way I can have them on is to have a 1 time alarm any ideas?
I've restarted the watch uninstalled the app on my phone and check DND and sleep mode and neither are on.
117 REPLIES 117
Why was this update pushed to me? It's been known to have issues for over a month! I need these alarms for work. Understand you affect people's livelihoods when pushing bad firmware to the public!
I did a test this morning and even though the repeating alarm was grey when I went to bed it still went off this morning at the correct time.
@DavidFitbit - It's now been two weeks since you said this issue had been escalated to a higher-level department and two months since initial reports that Fitbit broke our devices. What is the expected timeline for Fitbit to correct their error and restore functionality?
This issue has claimed another victim (me.)
Expect I am using an Inspire 3 -- I have updated, saw the problem, done a factory reset and now cannot re-setup.
For Inspire 3, factory reseting did seem to reset the update. I had trouble with re-setting up my device, and had to manually "Forget" the bluetooth device in my Android phone.
I cant speek for your device.
Same issue here. I don't know if I was more infuriated or relieved to find this thread. This does explain why I somehow slept past my alarm every day this week...but I can't believe this has been a known issue for this long and isn't resolved yet.
Thank you for sharing this! I was having the same problem, and your comment helped me know how to fix it.
🙋🏼 I've also been sad about this issue since the firmware update - but on my Inspire 3! 😒
how is this still broken?
I rely on this functionality, and it's a major reason why I purchased another Fitbit - I've been using Fitbit for years and just bought this Charge 6 to replace my Charge 5.
Having the same issue here in Ireland.
Same, very disappointing this issue was reported a almost 2 months, firmware was still pushed to my devices and another month later this still hasnt been resolved. Its an alarm application, seems like a pretty basic piece of SW
Can we get an update on this please? I have two affected inspire 3s and a brand new Charge 6 that I see the red dot for the update wanting to install for a few weeks now, and I refuse to install it. I need to adjust notification settings on my Charge but I can't because I have to do the update first.  This is very inconvenient.
Just adding another voice to this still being broken. Absolutely unbelievable that a dodgy firmware was pushed and hasn't been fixed. Having to set and reset alarms every day if you wake up at different times is insane. I have different wake up times depending on gym classes and work and have to set and reset everything daily because repeat alarms don't work.
When can we expect a fix?
Ugh yet another voice adding to this...I held off updating my charge 6 until it went from 100% to 0% battery in 1 hour the other day - I thought oh no not again (this is effectively my 4th replacement device due to the battery drain issue following updates on my previous fitbits).
Except I realized I never updated so I figured let's give that a try, if updating screwed up the battery on the others, what's the harm in updating at this point? well now the thing is holding a charge again but my alarm is having the same reported issue. And to find this thread posted TWO MONTHS AGO with no fix?
Yeah, no. I'm done. This is the last fitbit I will ever own.
The inspire 3 that I have that's effected by this, is still under warranty. Can I return it for a replacement? If so will the new one have the same broken features? Sure would be a lot easier to just have an update pushed to the device I already have...
It's been months now, and it's been a while since an update has been made. Is this issue getting resolved? Or is it on the back burner and forgotten about?
I've brought this to support twice now, linking this issue... we'll see if that helps anything? Shrug.
Also if Support suggests factory reset and resync device... Do it! it actually works!? You will list your day's activity but then the alarm will actually work going forward (it will still look broken but it actually works)
EDIT to add the good news
Hello,
It has come to my attention today after an update was pushed to my Fitbit that it contained issues that are currently unresolved which your company has been aware of for over two months. Now, as I am sure that you are aware, any such major issues with the usage of this item (such as the current issue, which revolves around the loss of the use of recurrent alarms and or the inability to set an alarm on certain days or further than twenty-four hours ahead) that make it incompatible with the original intended use could and should fall under the EU consumer rights policy umbrella. For those who are Fitbit owners in Sweden, for example, these protections have been secured for consumers in Sweden through the consumer purchases law (2022:260; konsumentköplagen), which states as follows:
"4 kap. Fel på varan
Krav på varan
1 §   Varan ska i fråga om art, beskrivning, mängd, kvalitet, funktionalitet, kompatibilitet, driftskompatibilitet och i övrigt stämma överens med vad som följer av avtalet. Varan ska åtföljas av de tillbehör, anvisningar och uppdateringar som följer av avtalet.
Varan ska vara ägnad för det särskilda ändamål för vilket konsumenten avsåg att varan skulle användas, om konsumenten har informerat näringsidkaren om det särskilda ändamålet och näringsidkaren vid köpet har godtagit att varan kan användas för det ändamålet.
2 §   Varan ska, utöver vad som följer av 1 §,
   1. vara ägnad för de ändamål för vilka varor av samma slag i allmänhet används,
   2. stämma överens med kvaliteten på och näringsidkarens beskrivning av ett prov eller en modell som har gjorts tillgänglig för konsumenten före köpet,
   3. ha den mängd och de egenskaper och andra särdrag i fråga om hållbarhet, funktionalitet, kompatibilitet, säkerhet och särdrag i övrigt, som är normalt förekommande för varor av samma slag och som konsumenten med fog kan förutsätta med hänsyn till varans art,
   4. stämma överens med sådana uppgifter om varans egenskaper och andra särdrag eller användning som näringsidkaren eller någon i ett tidigare säljled eller för näringsidkarens räkning har lämnat vid marknadsföringen av varan eller annars före köpet, och
   5. åtföljas av den förpackning och andra tillbehör samt anvisningar för installation, montering, användning, förvaring och skötsel som konsumenten med fog kan förutsätta.
4 §   För en vara med digitala delar ska näringsidkaren se till att konsumenten informeras om och tillhandahålls säkerhetsuppdateringar och andra nödvändiga uppdateringar.
Vid ett enstaka tillhandahållande av ett digitalt innehåll eller en digital tjänst gäller näringsidkarens skyldighet enligt första stycket under den tid som konsumenten med fog kan förutsätta uppdateringar. Vid kontinuerligt tillhandahållande av ett digitalt innehåll eller en digital tjänst under en period gäller skyldigheten under tre år efter det att varan med digitala delar avlämnades eller den längre tid som avtalet löper.
Fel på varan
5 §   Varan är felaktig om den avviker från vad som anges i 1 eller 2 § eller näringsidkaren inte uppfyller sin skyldighet enligt 3 eller 4 §, om inte något annat följer av 6-8 §§. I 9-12 §§ finns bestämmelser om att varan kan vara felaktig även i andra fall.
6 §   En vara som avviker från vad som anges i 2 eller 4 § ska inte anses felaktig, om näringsidkaren vid köpet har informerat konsumenten om avvikelsen och konsumenten uttryckligen och separat har godkänt den.
7 §   En vara som avviker från vad som anges i 2 § 4 ska inte anses felaktig, om näringsidkaren visar att
   1. uppgifterna har rättats före köpet på ett sätt som är likvärdigt med det sätt som uppgifterna först lämnades på,
   2. uppgifterna inte har inverkat på köpet, eller
   3. uppgifterna har lämnats av någon annan än näringsidkaren och att näringsidkaren inte kände till eller borde ha känt till uppgifterna.
8 §   En vara med digitala delar ska inte anses felaktig om den avviker från vad som anges i 1 eller 2 § enbart till följd av att konsumenten inte inom skälig tid har installerat en uppdatering som har tillhandahållits enligt 4 §. Detta gäller dock endast om näringsidkaren har informerat konsumenten om att uppdateringen finns tillgänglig och om konsekvenserna av bristande installation, och konsumentens bristande installation inte har berott på anvisningarna för installationen.
9 §   En vara som avviker från vad som anges i 1 eller 2 § till följd av bristande installation av varan ska anses felaktig, om den
   1. har installerats av näringsidkaren eller av någon annan för dennes räkning som ett led i att fullgöra köpet, eller
   2. har installerats av konsumenten eller någon för dennes räkning och avvikelsen beror på de anvisningar som har tillhandahållits av näringsidkaren eller, i förekommande fall, av leverantören av det digitala innehållet eller den digitala tjänsten i en vara med digitala delar.
Näringsidkarens ansvar för fel
14 §   Näringsidkaren svarar för fel på varan som har funnits vid avlämnandet och som visar sig inom tre år från denna tidpunkt. Om näringsidkaren har åtagit sig att som ett led i att fullgöra köpet installera varan, gäller ansvaret för fel från när installationen har utförts av näringsidkaren eller av någon annan för dennes räkning.
För en vara med digitala delar där det digitala innehållet eller den digitala tjänsten tillhandahålls kontinuerligt under en period, svarar näringsidkaren för fel på innehållet eller tjänsten som uppstår eller visar sig under tre år efter det att varan med digitala delar avlämnades eller den längre tid som avtalet löper.
Om konsumenten inte i rätt tid hämtar eller tar emot en vara som hålls tillgänglig för konsumentens räkning och varan försämras därefter, svarar näringsidkaren för försämringen, om den inte enbart beror på varans egen beskaffenhet. Om en försämring av varan uppkommer efter avlämnandet, svarar näringsidkaren för försämringen, om den är en följd av näringsidkarens avtalsbrott.
15 §   För en vara med digitala delar svarar näringsidkaren för fel till följd av bristande uppdatering under den tid som gäller för näringsidkarens skyldighet att uppdatera det digitala innehållet eller den digitala tjänsten.
17 §   Ett fel som visar sig inom två år efter det att varan avlämnades, eller i fall som avses i 14 § andra stycket inom den tid som anges där, ska anses vara ett fel som näringsidkaren svarar för, om inte näringsidkaren visar något annat eller detta är oförenligt med varans eller felets art."
Now, I am extremely aware that in my case, I bought my Fitbit Charge 6 in November of 2023. At the moment, the issue may lay with Fitbit software which may be handled internationally, but that doesn't mean that every single owner of Fitbit hardware that currently resides within the EU that has bought a Fitbit within the last few years (each country of the EU was allowed to set their own statutory guarantee period, but there is a set minimum) currently has the legal right to make a claim on the grounds of "fel i varan" (item defective from the beginning) due to these aforementioned issues
It's time to either fix these issues immediately, or your company will be shelling out reparations on the international level very soon.
As I mentioned in a previous post, the repeating alarm will still work as intended. Just test it out one morning. Set your repeating alarm and then set a separate individual one for like 5 minutes later to cover yourself.
While it is annoying that it doesn't look like it's going to work, after I tested it I haven't had any issues waking up with my alarm when I need to.
A lot of other stuff on the watch doesn't work like it used to which annoys me.
Give me either the option to downgrade or fix it.
