@JamoC You can't do that with the new UI. All exercises are available on the device, however, your three most recent used workouts will appear at the very top of the list. So if you always use Walk, Treadmill, and Weights, they will consistently populate first in the list after selecting them at least once.
@Heather-S Thanks for your input. That is correct!
@JamoC Nice to see you again on the forums.
Thanks for your post about the training shortcuts on your device. Please note that there is no setting to do this manually. However, the list of trainings will rearrgange itself based on the activities you start the most. Eventually you will see them at the top of the list as explained above. I appreciate your understanding and patience regarding this matter.
That is not ideal, especially since I use yoga the most - and it's at the very bottom. How many times do you have to use it for it to come to the top? Although it's great there are more options with the Charge6 - I wish there was a way to reorganize them and choose the preferred exercises like the previous Fitbits. Not happy about that.
Hello @nelsonkeller
I believe you only need to select and complete a Yoga session once and then it will be at the top as one of your 3 most recent activities.
I use "Workout" for my VR exercise sessions, which is also towards the bottom. After I completed 1 "Workout" session, that activity stays in my most recently used. I just have to be careful not to select more than 2 other activities. Otherwise, I have to scroll down to select "Workout" again.
Thanks. I suppose that's the best we can hope for...
