06-04-2024
05:03
11:57
RodrigoMFitbit
06-04-2024
05:03
11:57
RodrigoMFitbit
I'm frustrated:
How do I get back to the time / home screen, when Im recording a training session? I was on the bike to the train, wanted to try recording the exercise - but then of course needed the time. Any ideas?
Best AnswerDo you have the option of auto-detecting exercises on in the Fitbit app? Then, you won't need to go back and record the time: it will retroactively do it after 10 min. of elevated heart rate.
one cruise ship at a time!On the Charge 6, if you have the current firmware, you'll see the current time on the activity screen, at the top. If that's too small to read, you can tap the screen to cycle through different stats (HR, calories, etc.), the current time being among them.
@mikey_pdx @DramaQueenDiva Thanks for your input and suggestions. Top!
@SunsetRunner Welcome to the forums. Thanks for reaching out about going back to the home screen while an exercise is being recorded.
This is currently not possible. In order to go back to the home screen, the recording must be stopped. However, as mentioned here above it is indeed possible to check the time even if the training is running on your device. It will be shown at the top of the screen or you can tap on the screen to cycle through the stats and eventually you will see the time.
However, if you would like to go back to the home screen for other reason that just checking the time, I recommend you post this as a suggestion. The best place to make your voice heard is the "Product Feedback" board, where you can submit your ideas and share it with other members. The suggestions with more votes are taken into consideration by our developers for new updates or product development.
