01-18-2025 04:19
01-18-2025 04:19
I had a Charge 5 that died recently so I upgraded to a Charge 6. Before when I was exercising, I could see the calories burned at the top, my heart rate in the center and the amount of time I had exercised at the bottom on the watch. Charge 6 updated it to show the current time at the top. I know I can flip through to see how many calories I burned during the workout but I liked seeing all the stats at once. Is there anyway to remove the current time when exercising?
Best Answer01-18-2025 07:37
01-18-2025 07:37
Hi, @KittyMom1074 , unfortunately it is no longer possible to choose top and bottom stats on your exercise app on the Charge 6 (or the Charge 5 since update). The top and bottom stats are now fixed, and you will need to swipe through to change your middle stat. Your middle stat will stay the same until you swipe again. I am sorry not to have a better solution for you.
01-18-2025 07:37
01-18-2025 07:37
