I remember quite a while back that Fitbit was going to do an update (to fix an update) to add back in sleep ranges, but I never got that one. I get the percentage and amount of time but there is no range to say what is normal, just the dotted area to show normal amounts. Does anyone get the ranges now or is the dotted area now the norm?
Best AnswerHello @Kathylynn103
If you are asking about the ranges showing the lower and upper values, I haven't seen those since the sleep section was redesigned. I only see the dotted area minus the lower & upper values.
Yes, that's what I mean. I thought I read a discussion that indicated Fitbit was going to add those upper and lower numerical ranges back in, but I haven't seen that happen. Just wondering if that is still in the works or not. Thanks!
Best AnswerYou're welcome @Kathylynn103 .
If they do decide to bring back the values, we should see it in an app update. Also, if I learn that there's a plan to re-instate them, I'll report back & let you know.
