10-28-2025 03:05
10-28-2025 03:05
Since the change in sleep tracking, I am getting different results from the weekly summary versus the daily sleep record. Yes, I track the exact same days. One week I got a weekly summary of 7 hours, 11 minutes on my weekly summary (as reported in the email update) but my daily record amounted to 6.67 hours. The following week, the summary report was 6.49 hours, the daily record totaled 5.82 hours. The sleep data is no longer reliable and is essentially worthless. PLEASE fix it.
10-28-2025 12:22
10-28-2025 12:22
Hello @sinkcar
You're not the only user to experience this discrepancy in sleep stats. As best as I can tell, the sleep stats that you see in the Fitbit app are using the updated sleep algorithm. The weekly report, however, seems to use the old sleep algorithm.
At this time, you can submit this issue using the Feedback option in the Fitbit app
The feedback reports are received by the team for review.
Best Answer10-29-2025 04:34
10-29-2025 04:34
Best Answer10-31-2025 13:09
10-31-2025 13:09
Hello @sinkcar
You're not the only one who believes the new algorithm isn't good. If you haven't done so yet, make sure to use the Feedback option to express your opinion. As I mentioned, the team receives the feedback reports for review.
10-31-2025 13:53
10-31-2025 13:53
