11-20-2024 10:16
11-20-2024 10:16
Hi! I just received my Fitbit 6 and my heart rate isn’t showing or my bpm and my sleep stats aren’t working. This is my first day with it and I’m disappointed that these aren’t working
11-20-2024 12:40
11-20-2024 12:40
11-20-2024 10:51
11-20-2024 10:51
Hello @BaileyWins
It sounds like your heart rate sensor isn't on. Do you see a green light on the back of your Charge 6? That's the heart rate sensor. You can check it by placing your finger across the back of the device. When you lift your finger, you should see the green light.
If you don't see the green light, the first place to check is the Settings menu on the Charge 6 and confirm Heart Rate is on.
11-20-2024 12:40
11-20-2024 12:40
11-21-2024 14:28
11-21-2024 14:28
Hello @BaileyWins
Thank you for your update and letting us know you figured out that your sleeve tattoo was the culprit. Glad that you were able to get your Charge 6 to work when you switched it to your right arm. 👍
