05-09-2024 23:49
05-09-2024 23:49
My charge 6 only starts tracking my sleep around 3:00 in the morning, while I generally go to bed around midnight.
05-10-2024 06:33
05-10-2024 06:33
I’m having the same issue on my Charge 6. I go to bed around 10 and get no data until 3.
05-10-2024 15:20
05-10-2024 15:20
Hello @Weerhuis & @ToniO1955
Have you had a chance to try to edit your sleep log in the Fitbit app to see if there's additional tracked sleep data?
Every now & then, my Fitbit doesn't properly track my sleep start and/or wake times. When this happens, I edit my sleep log in the Fitbit app. To edit the sleep log:
It used to take a bit of time, about an hour or so, for the app to update all my sleep info, including score & sleep stages graph. After the sleep section was updated, I notice that it doesn't take as long for the app to update all the data.
06-02-2024 03:01
06-02-2024 03:01
My apologies for my late reply.
i have tried your suggestions, unfortunately no changes. I go to bed around 23:30, the charge 6 only starts registering sleep as from around 2:30
06-02-2024 11:45 - edited 06-02-2024 11:46
Hello @Weerhuis
If I understand your reply correctly, you aren't seeing additional sleep stages data after you edit your sleep start time.
It would be helpful if you could share screenshots of your sleep stages graph before and after you edit your sleep start time.
