Sleep tracking removed on Charge 6
My app and tracker recently updated and with the latest software I can no longer see my sleep score or the sleep cycles even though we were told that feature will be part of the free extras. What happened???
3 REPLIES 3
Hi @DannyLyubenov, welcome to the Fitbit Community!
Thanks for sharing with me your current situation with your Charge 6 sleep tracking feature.
As a first recommendation could you confirm if your device is properly updated, you can follow recommendations and steps in this following article: Update your Fitbit device.
Then if the situation persists read this article that might also help you: How do I track my sleep with my Fitbit device.
Mine is also gone. Disappeared from the "swipe up" metrics on my Charge 6. I now only have HR and SPO2. Literally never use SPO2. Sleep duration and score are a big reason I have a Fitbit and I can't see the sense in this.
Unless it *is* supposed to still be there?
Mine is still there, though I never look at it on the fitbit itself. I have the most recent firmware and Android app. Does it show up in the app for you? If it's in the app but not on the fitbit, you might be able to get it back using a factory reset (as long as you sync before you do it, it'll sync back all your data afterward).
