09-09-2024
03:18
09:56
LizzyFitbit
09-09-2024
03:18
09:56
LizzyFitbit
Today suddenly my fitbit start to show the wrong time.
My time zone is Bangkok GMT+7:00 but the watch show the UTC time.(7 hours slower from my time zone)
I've try change to other location with GMT+7:00 in the setting but it still show the UTC time.
Meanwhile, I've tried Tokyo GMT+9:00 the time is shown correctly. (2 hours faster than my time zone)
Is there any way to fix this or is this somekind of bug?
09-09-2024 08:11
09-09-2024 08:11
Running into the same issue from India as well. Tried all possible "solutions" but the time won't change for timezones other that UTC, EST, PST and Australian Time. 😞
This is so weird.
Best Answer09-09-2024 08:13
09-09-2024 08:13
Time on FitBit suddenly changed to minus 5 hours 30mins. How to restore?
Best Answer09-09-2024 08:17 - edited 09-09-2024 08:30
More or less the same happened to me today - without traveling, it moved 4 hours behind my TZ. I'm GMT+4 and it shows GMT. I can set GMT minus anything, but when I set TZ GMT plus something it doesn't show more than GMT.
I tried everything I found on the Internet - enable/disable automatic location/TZ, log out of the app, reinstall the app, restart, hard restart, reset Charge 6, pair/unpair, restart, hard restart iPhone - all these in different combinations. Nothing helps. I even changed my location in my Google account and payment method.
BTW, it logs the workout with the correct time into the Fitbit app while showing the wrong time on Charge 6.
09-09-2024 08:19
09-09-2024 08:19
I kept my country (Brazil) and tried Fortaleza, Recife, Sao Paulo, Belem, Araguaina, Bahia, Boa Vista.... Most cities the app un-selects immediately after I select. Sao Paulo works most of the time, as it remains selected, but it's still 3hrs ahead of what it should be. Same for Cayenne (french Guiana) and Suriname. I just can't win today.
09-09-2024 08:35
09-09-2024 08:35
I am having the same issue. Time being shown is UTC, while my time zone is UTC plus 5.30 hours. I have restarted the fitbit and synced it but nothing happens.
Can any body help.
09-09-2024 08:46
09-09-2024 08:46
Hi, at some point today my watch time has reverted to UK time.... I live in Turkey, and my clock was on the right time first thing this morning... while I was on my walk and checking my steps I noticed the time had gone back 3 hours, I checked my phone and my location services are switched on, I checked tue fitbit app, my time zone says istanbul, but my location says UK, I tried to set location to automatic and nothing changed, so I tried to set my location to ustanbul, but turkey isn't in the location list... thanks for any help anyone can offer
Best Answer09-09-2024 08:51
09-09-2024 08:51
09-09-2024 08:53
09-09-2024 08:53
Having the same issue. Time is 4 hours ahead even though my phone time is accurate.
09-09-2024 08:55
09-09-2024 08:55
I am from India and facing the same issue. Time in fitbit charge 6 is 5.30 hours behind.
Any inputs to get this fixed?
09-09-2024 08:57
09-09-2024 08:57
Having this same problem as well.
Suddenly showing UK timezone when I'm in Singapore. Did not travel at all.
09-09-2024 08:59
09-09-2024 08:59
Same here...I think its a bug !
Best Answer09-09-2024 08:59
09-09-2024 08:59
I am facing the same issue as well
Best Answer09-09-2024 09:00
09-09-2024 09:00
Same problem in versa 4 always showing gmt timezone whatever I do even factory reset did not help
Best Answer09-09-2024 09:02
09-09-2024 09:02
My Fitbit Charge 6 time showing wrong ! Cannot reset/change , tried everything from factory reset , app delete n all. Fitbit please fix it !
09-09-2024 09:02
I also live in Brazil. Same issue. It started some hours after I woke up. Tried everything. Resetting, resynchronization, change time zones. Nothing works...I loved this watch until now. It seems Google is scrapping Fitbit brand in favor of their Pixel brand...
Best Answer09-09-2024 09:04
09-09-2024 09:04
Im having the same problem asia/ oman and i dont know way i tried servel things and nothing worked
09-09-2024 09:04
Best Answer09-09-2024 09:05
09-09-2024 09:05
yes same problem here.
Best Answer09-09-2024 09:09
09-09-2024 09:09
I’m also having the same problem here in Asia. I changed it to MT (America/Denver) and it worked to sync to that time but all Asian time zones don’t seem to work.
Best Answer09-09-2024 09:11
09-09-2024 09:11
Hello @Daltug and welcome to the Community. There are several posts from international users about a time problem and they are all off by three hours. Somehow your post wound up in a forum for a device that is only available in the US. What model Fitbit do you use and do you use an Android or iPhone?
Laurie | Maryland
