01-22-2024 05:08
01-22-2024 05:08
How can I modify the tme?
01-22-2024 06:48
01-22-2024 06:48
Hi, @KrM62 your Fitbit is designed take its time from the internet (via your phone) when you sync. It cannot be manually altered. If the time is incorrect on the Fitbit, and the time is correct on your phone, it is likely that it didn’t sync fully and you will need to try to force another sync.
The exception to this is if you have recently changed time zones. Sometimes the Fitbit seems to be stuck in the old time zone even though your phone has updated. In that case it sometimes needs an extra nudge to update the time. If this is your situation please let us know and I can provide the steps that usually fixes this issue.
Welcome to the forums!
