this article has some suggestions on how to find your device - click to read. You can also try sending a text to yourself if you have notifications set to go to your device. You must be within range (25 feet or so) to hear it buzz. It's better if the device is near some paper or a hard surface as it makes the sound louder.
Hello @Zane_Loewen and welcome to the Community. Sorry to hear that you lost your Fitbit. This Help article has suggestions for you. It also has recommended Bluetooth finder apps for each platform. If you can sync your Charge 6, then it is in Bluetooth range, about 30 ft clear line of sight. Fitbits sync every fifteen minutes when you have the app running in the background. You might get a better idea of where to look if you check on its last sync time.
Laurie | Maryland
