04-26-2024 00:23
04-26-2024 00:23
I have looked and looked in the settings, nowhere can I find how to permanently turn off vibration alerts for 300 steps? Or when my Fitbit thinks I've gone up 300 steps, when the alert goes off I have probably done over 1000 by then!
Also when walking, every 1000 metres? Or something like that it also vibrates.
I can turn these off daily, but not found how to permanently turn off!
Best Answer04-27-2024 12:26
04-27-2024 12:26
Hello @SteUK
Have you checked Notifications under Fitbit app settings? There's one for notifying you when you've reached certain percentages of your step goal.
To check:
Hopefully, this will disable the step notifications that you want to turn off.
04-27-2024 12:26
Hello @SteUK
To check:
Best Answer10-17-2024 01:07
10-17-2024 01:07
All push notifications are turned off and always have been turned off....it's vibrating even more now! Then ever, so annoying
10-20-2024 09:47
10-20-2024 09:47
This doesn’t work. I’m so aggravated since the last software update that I’m looking for a different brand of tracker.
10-20-2024 11:45
10-20-2024 11:45
This simply does not work. I went to my profile> Fitbit settings> push notifications> then turned everything off. I still get good job and zone minute alerts throughout the day. If this isn't resolved I will be moving to a different brand. I have tried to set my daily goals to zero and that is not allowed.
05-01-2025 04:10
05-01-2025 04:10
Despite all the misinformation on this site, DND mode is the only way to actually suppress these.
Best Answer05-02-2025 04:28
05-02-2025 04:28
Even DND doesn't disable the movement "achievement" notifications - you just can't shut this thing up.
07-06-2025 17:14
07-06-2025 17:14
Same here. Cant get rid of the " atta girls!" when i do simple stuff.
Best Answer07-09-2025 11:54
07-09-2025 11:54
Hello @Wyohunter
By any chance, did you disable the Health & Fitness Push notifications?
To check:
Best Answer07-25-2025 11:06
07-25-2025 11:06
