08-24-2024 07:48
08-24-2024 07:48
Hello,
My Charge 6 is off, and the only way to turn it back on is by placing it on its charging dock. As soon as I put it on the charger, it restarts, and as soon as I remove it, it turns off. The charge percentage seems unclear; it varies from one attempt to another. It can show 1%, 76%, or 100%. I suspect that my watch is no longer charging properly. I have tried restarting it manually and resetting it, but nothing works.
Any ideas?
Thank you in advance.
Best Answer08-24-2024 10:01
08-24-2024 10:01
Hi @Duplicial. Welcome to the community forums.
Thank you for taking the time to share this feedback with me. Thanks for trying to fix the device on your own.
Please, before considering other options take a look at this help article: Why isn't my Fitbit device's battery charging?
08-24-2024 10:24
08-24-2024 10:24
Hello @ManuFitbit. Thanks for your answer.
Unfortunately, nothing works.
Best Answer08-25-2024 15:10
08-25-2024 15:10
Hello @Duplicial
It sounds like you may have a defective device. Please contact Support (<-- click link). Complete the prompts until you get to the option to chat or call.
08-25-2024 15:17
08-25-2024 15:17
Thanks @RiekoC, I willl do that.
