06-30-2025 07:01
06-30-2025 07:01
I do not like the new calculation to get zone minutes. I do not think it is calculating correctly. Some days same intensity I have 20 to 30 minutes of exercise and zone minutes and other times with same workout 2 zone minutes. I have charge 6 and at times it is not picking up my heart rate. I have the fitbit placed up on the arm and tightened as recommended. Some people just want to stay healthy not become an athlete. Please fix this. Also how can we get the lab ads off our screen in the app. Very disappointed.
06-30-2025 11:43
06-30-2025 11:43
Hello @Javagrrl68
There hasn't been any changes to how Active Zone Minutes are awarded. You get AZM when your heart rate is within the various ranges.
Since you mention that you aren't always seeing your heart rate tracked, that could be the reason why you're not getting all your AZM. When you aren't seeing your heart rate being tracked on your Charge 6, check to see if you see a green light on the back of your device. The green light is the optical heart rate sensor.
You might want to check the Settings tile on your Charge 6 to make sure that Heart rate is turned on:
The team is aware of the issue with the Fitbit Lab banners on the Fitbit app. Last we heard was that a fix is supposed to be rolling out. However, we're not sure which app version has the fix. Users who have installed ver 4.46 have reported that the banners still are present, without a way to remove them.
Best Answer06-30-2025 18:07
06-30-2025 18:07
