11-15-2023
14:13
06:20
AndreaFitbit
11-15-2023
14:13
06:20
AndreaFitbit
Hi! Just want to know if anyone knows yet if the Charge 6 will be able to be used as a clip on like the Charge 5. TIA
Best Answer11-16-2023 08:01
11-16-2023 08:01
@cmelody The US Fitbit store sells a third party clip made by Wasserstein. The store says that you can use it on a Charge 6. Please keep in mind that the Charge 6 doesn't have an On wrist/On body option like the Inspire 3. The on Wrist/On Body option changes the sensitivity of the accelerometer, so step counting might be off. Please keep this in mind if you use this clip with the Charge 6.
Laurie | Maryland
11-16-2023 08:01
Laurie | Maryland
Best Answer11-16-2023 09:36
11-16-2023 09:36
Thanks for the response. I have the Inspire 3, which is a joke and that is why I was wondering about the Charge 6.
Best Answer10-18-2024 21:00
10-18-2024 21:00
What is your issue with the Inspire 3? I ask because that is what I am using specifically because I wanted to be able to use it with a clip. I would love to use my Charge 5 with a clip, but since the software isn't there to support it, it doesn't work as well. It also drains the battery faster with the heart rate always trying to be read through a steel clip and jeans. With the Inspire 3 I can use it in Clip on Body mode during the day and switch it to Worn on Wrist mode for sleeping. I miss the ECG and EDA, but more accurate step counting is a higher priority for me.
