04-12-2024 01:33
04-12-2024 01:33
Due to the change in the running screen since the last update, I was wondering: does a reset to factory settings revert the Charge 6 to the old firmware?
Thanks!
04-12-2024 02:33
04-12-2024 02:33
Hi, @Penzel no, even a reset to factory settings will not return to an older version of the firmware. Once you have updated your Fitbit to a new firmware version it is not possible to return to any previous version.
04-12-2024 02:33
04-12-2024 02:33
04-12-2024 02:37
04-12-2024 02:37
Thank you for your very quick reply, @Julia_G That is very clear and unfortunate.
Somewhat unrelated: I see you use a Charge 5, does it display the distance at the top of the running screen? Or the time?
