annulla
Mostra  solo  | Cerca invece
Intendevi dire:
fitbit charge 6 - Trova il mio dispositivo
non capisco perchè il fitbit charge 6 non rientri nella rete di Google "Trova il mio dispositivo".
In caso di furto o perdita dell'orologio, come si può recuperare?
Soluzione accettata
1 RISPOSTA 1
@elsioramku
Welcome to the community.
A device needs an internet connection in order to be seen by the Find my device network.  The Charge 6 does not have that capability.
You would need a smartwatch with the ability to get an IP address in order to be located..
If the device is lost within range of your phone's Bluetooth and is powered on, there are Bluetooth scanners available on the Google play store that may be able to help locate the device.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Soluzione accettata
