Charge 6 - Manually log an activity (steps)
ANSWERED
with the new app for charge 6 required on phones in 2024, i now can not manually add missed steps.  i did not wear my fitbit when walking, and i can't add the missed steps for the day. i can manually add weight, sleep, but NOT steps. is there a way that i can do this?
Moderator's action: Clarified subject
1 BEST ANSWER
Accepted Solutions
perfect. hitting the today screen, then the little pencil in the upper
right hand corner to customize today, it shows the metrics to measure,
scroll down to activity, turn the exorcise days toggle on. then go back to
the main today screen, click on the "=" icon on the lower right screen, and
under manually log, activity shows up. then click on walk, and you can add
duration of activity and miles. this adds steps to the day that you
missed. thanks!
4 REPLIES 4
Have to manually add an activity, such as walk, that has steps. I forget the parameters for walk, but might have to play around with distance to get approx # of steps.
on charge 6, i open up to day. in lower right corner is the "+" symbol.
when i click on that it says i can manually log sleep, and weight. i don't
know how to add steps or distance so i can manually add those.
Hi @rdll   I use iOS and I noticed this on my Today screen.  I must have the Exercise tile toggled on to see the manual log options for activity.  This include Track live and Manually log.  The iOS and Android versions can be different, but I hope this is the same for both platforms.  A good guideline is that there are 2,000 steps per mile.
Laurie | Maryland
missed. thanks!
