01-13-2016 06:41 - last edited on 09-06-2020 20:15 by MatthewFitbit
I've used a Charge HR for a week now. I'm a 53 year old male, 186 pounds, 6 foot even. The calories burned for an hour walk are way too high and I'm frustrated. For instance, I walked 65 minutes yesterday at a moderate pace of 3 mph, I took 6070 steps which was just over 3 miles, 124 bpm. My daily BMR is 1730 so that equates to 72 an hour. Fitbit says I burned 598 calories for that walk. Deducting the 72, that's 526 calories for a 65 minute walk! I wish that were true but don't think it's possible. Does over 500 calories burned seem reasonable for a 65 minute walk?????
09-22-2016 11:31
09-22-2016 11:31
That's your BMR (basal metabolic rate, or the calories your body burns just to stay alive). Your BMR calories will increase steadily throughout the day whether you are wearing the fitbit or not.
@Nat2788 wrote:
None of this has helped. My tracker said I burned 500 calories whilst sleeping and I wasn't even wearing the Fitbit!!!
01-14-2016 08:37
01-14-2016 08:37
That does seem a little high to me. However, on my last walk it says I burned 269 calories in 41 minutes at an average bpm of 131. That equates to 7 cals/min. For 65 minutes at that rate it would be around 455. So assuming my tracker is correct (it always has been when I've checked it with other apps and equipment), I'm not sure if yours is too far off.
01-17-2016 15:51 - edited 01-17-2016 15:53
CalorieLab says your 65 minutes of walking 3.0 MPH should have been 302 calories.
My heartrate as measured during the walks is often 150% of what I expect it to be, and I think this skews the calorie count higher. I have a theory and that is that there is some light leaking behind the device due to long sleeves, arm hair, or whatever. I think I'm going to experiment with a dark and wide wristband to cover the watch, and either shaving the arm hair there under the watch or wearing the watch so that the sensors are over my inner wrist than my outer wrist. It's just a theory, but I am confident that my HR is being mismeasured and skewing my walk calories too high.
02-08-2016 10:26
02-08-2016 10:26
I have the same problem with calorie burn too high on walking. I have a Charge HR which I purchased about 2 months ago. All of the on-line calculators I have found (that include gender, height, weight, age, and pace) estimate a calorie burn of 7 kcal/min for a walk at 4 mph. My FitBit is always in the 8-9 kcal/min range even though my heart rate rarely gets above 75 beats per minute. On a typical day this is 200-300 calories burned that is credited but not real.
02-23-2016 21:39
02-23-2016 21:39
Same problem with my ChargeHR - was actually happier with my Flex!
45 yrs old male, 192 lbs, at 6 ft even. Being rewarded 500 calories for a 3 mile walk at 3 mph pace! Absotuely not correct. All the online walking calculators report a 3 mile walk at about about 300 to 320 calories. My FitBit Flex use to track at about 100 cal per mile, but my ChargeHR rewards 175 cal per mile.
I've tracked 3 mile walks with the heartrate monitoring of the ChargeHR on and off and get the similar results.
03-19-2016 14:00
03-19-2016 14:00
05-08-2016 11:10
05-08-2016 11:10
Bumping/replying so hopefully someone with a potential fix will respond. I'm a 31yr old female, 135lbs. I walk the dog at a pretty leisurely pace (with a 30lb baby on my back!) almost every day. A 45 minute walk (with a 10 minute stop at the dog park) usually records 320-380 calories burned. Considering my heartrate doesn't go above 85, that seems very high. This is especially worrying since when I go to the gym and focus on keeping my heartrate above 140 for 30-45 minutes on the stationary bike, my Charge only records 200-ish calories burned. In other words, same duration of activity, more effort, and yet, fewer calories burned. Something is clearly wrong.
My guess is that the charge dramatically overestimates the number of calories burned per step, because a bike set to high resistance (or a spin class) should burn much more than walking does. Hopefully FB will update the firmware with this in mind.
05-08-2016 11:43
05-08-2016 11:43
05-14-2016 23:50
05-14-2016 23:50
I've had the same exact problem with the charge HR, where as my Flex seemed to be far more accurate after i tweaked the settings over and over. That just doesn't seem work for the HR. There are only 4 things after personal experience and several math/science equations I have done that I have come to the conclusion of on why the calorie burnt count is way off.
1. If I use the fitbit app and track my exercise like a walk AND wear my HR, I get double the calories. Is that because the app is tracking what you do along with the HR and adds both together for the wrong reading?
2. Does the HR detect the actual workout activity AND the movment sensed from your arm moving AND your heart rate then add all those 3 toghhter to get the higher calorie reading?
3. When you do workout, your BMR (which fitbit calories burnt is based off of) does raise from the extra exertion in activity, does that add and count as the higher calorie burnt reading?
4. The entire software/hardware and algorithm fitbit uses is just pure garbage and altogether wrong?
I find number 4 to be the most plausible reason but this is all just based on personal experience with both the Flex (which i had problems with for 13 months) and the HR for 2 months so far.
05-15-2016 11:45
05-15-2016 11:45
05-17-2016 04:23
05-17-2016 04:23
05-19-2016 09:42
05-19-2016 09:42
05-19-2016 11:30
05-19-2016 11:30
05-19-2016 16:27
05-19-2016 16:27
05-19-2016 18:39
05-19-2016 18:39
I agree! "Adjusting" your height/weight inputs to some imaginary number is entirely the wrong answer!
07-18-2016 17:58
07-18-2016 17:58
07-18-2016 20:11
07-18-2016 20:11
07-28-2016 06:17
07-28-2016 06:17
@wzlstx A warm welcome to our Fitbit Community! So sorry to hear that your calorie burn is to high when you walk and low when you do intense cardio. I'd like to know if the explanation that my friend @dlhnj provided helped. If not, make sure that your height, weight and gender entered on your Dashboard is correct. Finally. restart your tracker as advised in Alejandra's post and test your tracker's calorie burn after trying a test workout.
Keep me posted on the outcome my friend and I'll be around!
09-14-2016 23:21
09-14-2016 23:21
09-22-2016 11:31
09-22-2016 11:31
