12-03-2016 09:31 - last edited on 09-06-2020 20:15 by MatthewFitbit
Can I change the default display on my Fitbit Charger HR to STEPS?
12-05-2016 06:41 - edited 12-05-2016 06:43
Thanks for taking a break from stepping to visit the Community @bidobrikim! All Fitbit trackers display certain all-day stats, and most let you rearrange the sequence that stats appear and delete stats that don't interest you.
If you have a Fitbit Alta or Fitbit Charge 2, you can change your stats in the Fitbit app:
For all other trackers, you must use the fitbit.com dashboard.
I hope this helps, keep me posted! 🙂
P.S. Just wanted you to know that I've gone ahead and moved your recent post to the Charge HR board. Hope this helps you to receive a response you're looking for. 😉
04-30-2019 06:40
04-30-2019 06:40
Hello !
How come we can change the display settings on the Charge 2, but not on the Charge 3 ?
After the last update, there are more informations showing and I would have loved to switch some off and change the order. I've spent hours looking for ways to do it, and it simply seams we can't, can we ?
06-11-2019 11:30
06-11-2019 11:30
@bidobrikim wrote:Can I change the default display on my Fitbit Charger HR to STEPS?
09-26-2019 20:41
09-26-2019 20:41
Did you ever get an answer? I want steps (not the progress bar), but I can’t figure how to change the display on my watch.
