07-05-2016 21:38 - last edited on 09-06-2020 20:15 by MatthewFitbit
Hello,
My Charge HR every time that gets uncharged won't sync with my phone like it used to before. I have to go on and restart the Fitbit in order for it to luckily sync the first time around. Sometimes I have to restart it a couple of times.
07-29-2016 04:32
07-29-2016 04:32
07-30-2016 07:42
07-30-2016 07:42
I managed to get the HR to sync by uninstalling the Fitbit Connector and reinstalling. Then when I hit "Sync" it actually worked. Thanks for the help.
07-31-2016 04:41
07-31-2016 04:41
Great to see you around @masjoanne and @cherries. If your tracker is not syncing with your computer, follow our syncing troubleshoot directly from it. Now @masjoanne, it's great to hear that your tracker is now working, if you need anything else, do not hesitate in posting it.
Keep the stepping up!
07-31-2016 07:09
07-31-2016 07:09
07-31-2016 07:37
07-31-2016 07:37
it stop working it shows like its trying to sync but doesnt and then it turned off
07-31-2016 08:37 - edited 07-31-2016 08:38
@adelgado1962 welcome to the board.
It sounds as if your tracker has a low or bad battery, I suggest plugging it in let it charge some and try a sync while it is plugged in.
Let us know whether it works or not, we can go from there.
Ps: I've moved your post from the unrelated thread to here.
08-01-2016 04:06
08-01-2016 04:06
Thanks for stopping by and the recommendations @Rich_Laue. Great news @cherries! It's good to hear that your will be receiving a new tracker. At the moment of receiving the replacement device, do the following from a computer to set it up.
1. Click the Fitbit Connect icon located near the date and time on your computer.
2. Click Open Main Menu.
3. Click Set Up A New Fitbit Device.
4. Click Existing User and log in to your account.
5. Choose your tracker and follow the onscreen instructions to continue.
Welcome to the Forums @adelgado1962, have you tried the troubleshoot provided in the previous post to fix the syncing inconvenience you have? If you haven't, please do.
Let me know the outcome.
08-01-2016 06:04
08-01-2016 06:04
08-01-2016 23:45
08-01-2016 23:45
08-02-2016 00:14
08-02-2016 00:14
Its been charging but does nothing. very upset
08-05-2016 08:56
08-05-2016 08:56
I noticed the same problem. I have only had the Fitbit Charge a couple of weeks now. The first time the battery drained totally and was re-charged, it wasn't synching properly. This morning I noticed the time was off. I resynched with my computer and it seems to be OK now. But, will monitor it.
08-05-2016 21:53
08-05-2016 21:53
08-06-2016 15:47 - last edited on 08-07-2016 04:18 by HelenaFitbit
I have called Fitbit and found them to be very responsive. Good luck.
Moderator edit: Removed personal information.
08-06-2016 21:40
08-06-2016 21:40
@adelgado1962 did you use the web based contact form, the link can be found in the upper right, and also in the app under help.
08-10-2016 05:37
08-10-2016 05:37
My Charge HR stopped syncing to my phone (Android) so I followed the instructions to restart the Fitbit. It restarted and then when I went to set it up in the Fitbit App, I still couldn't connect it. My bluetooth kept saying that the pairing was rejected by the Fitbit, so I haven't been able to set up my Fitbit or sync at all.
Is there anything I can do?
08-10-2016 07:13
08-10-2016 07:13
Hello all, I hope you are doing fine! If your trackers are not syncing, I recommend following our troubleshoot at the I can't sync my tracker article, after these steps your devices should work properly.
I hope this helps, let me know the outcome.
08-10-2016 07:16
08-10-2016 07:16
Hi, I've already tried all those steps. It isn't working.
08-10-2016 07:19
08-10-2016 07:19
Thanks for the information @EricaE. If you have already tried these steps without success, feel free to contact our support team, I know they will be more than glad to help you out. For a faster response you can select the phone or chat options.
Let me know how it goes.
08-13-2016 20:30
08-13-2016 20:30
@EricaE the BT settings screen is the wrong place. If your tracker is still connected to your account, open the app, log into your account of needed, you should be setup.
If you have disconnected the tracker from the account you will need to use the app to set it up again.
08-23-2016 04:37
08-23-2016 04:37
