07-05-2016 21:38 - last edited on 09-06-2020 20:15 by MatthewFitbit
Hello,
My Charge HR every time that gets uncharged won't sync with my phone like it used to before. I have to go on and restart the Fitbit in order for it to luckily sync the first time around. Sometimes I have to restart it a couple of times.
08-27-2016 10:14 - edited 03-02-2017 00:22
Reinstalling as a new device will erase the history on the tracker, what should have been done is reinstall as a replacement device to the existing tracker that was not removed from the account.
But _ before trying any of the above
08-29-2016 05:48
08-29-2016 05:48
I haven't been able to sync my HR to my phone since Saturday. I've tried restarting my HR several times and that hasn't worked. I've tried uninstalling and reinstalling the app. Can't get it to sync to my computer either. I've made sure that my phone was compatible. I've made it to where there was no HR on my account and then reinstalled it. I'm getting tired trying to get this thing to work. Everyone that I know that has an HR has the same problems. Is there something that I haven't tried that may get it to work. This is my second HR because my first one fell apart after 6 months.
09-11-2016 07:49
09-11-2016 07:49
10-09-2016 18:19
10-09-2016 18:19
my ChargeHR synced yesterday, Oct 8 at 9;21 but can not get it to sync today.. I am very new to this . Using my Windows 10 computer
10-11-2016 17:04
10-11-2016 17:04
10-13-2016 09:10
10-13-2016 09:10
10-13-2016 09:17
10-13-2016 09:17
10-13-2016 18:25
10-13-2016 18:25
01-10-2017 05:20
01-10-2017 05:20
i got my first Charge HR in June 2015, it lasted 10 months, got a new one April 2016. now it will not sync. the days it did sync it didn't get all the steps that I did. for $150.00 this is lousy
01-10-2017 07:20
01-10-2017 07:20
01-10-2017 07:54
01-10-2017 07:54
01-10-2017 13:28
01-10-2017 13:28
Mine did the same thing. I deleted the device from the app, and then put the Charge HR on the wall charger and held the select button on the side for 10-15 seconds, the Fitbit will turn off. Go into the app and add the Charge HR as a new device and it should work.
01-11-2017 01:56
01-11-2017 01:56
When will the LG V20 be added? My Charge HR synced fine at first and now it is not syncing and it is not on the list of compatible phones.
02-08-2017 11:23
02-08-2017 11:23
I have tried all the steps listed to restart, reload and reboot but my Charge HR will not connect to the app on my iphone 6s. All it says is it's looking.
02-08-2017 12:49
02-08-2017 12:49
02-08-2017 12:53
02-08-2017 12:53
02-08-2017 13:45
02-08-2017 13:45
My issue started after I sync'd the HR with my iPad. The next time I tried to sync it with my iPhone but no luck. Today I tried all the suggestions but nothing worked. I finally gave up and attempted to sync it to my iPad again and it worked. Oh Well!!??!!
03-01-2017 16:59
03-01-2017 16:59
Charge HR will not sync for last few days. I have tried troubleshooting recommendations to no avail
03-01-2017 17:44
03-01-2017 17:44
03-01-2017 19:08
03-01-2017 19:08
