06-14-2016 22:09 - last edited on 09-06-2020 20:15 by MatthewFitbit
06-15-2016 08:21
06-15-2016 08:21
Hello @BryanTan, welcome aboard to our community. So far as my knowledge goes we don't have direct support in Singapore. So if you need any help I would suggest either contact us directly using the Chat or Email channels that we have available for customer support. Also you can share your concern here in our community and I or any other of my teammates will address your concern.
Let me know how it goes, I'll be around.
06-15-2016 12:59
06-15-2016 12:59
04-29-2017 07:20 - last edited on 05-01-2017 08:40 by RobertoME
My Fitbit also stopped working in less then 6mths after I got it. Did you manage to find out where to fix it?
Moderator Edit: Word Choice
05-01-2017 11:11
05-01-2017 11:11
Hi there @Anastasia_SG, thank you for joining us to the Fitbit Community. Note that we don't have repair centers in any country where Fitbit trackers are sold.
Let me know more details of the issue you are experiencing with your Fitbit tracker and I would be happy to provide you further assistance.
I will be looking forward to your response, hope to see you again!
05-03-2017 18:00
05-03-2017 18:00
Hi, my fitbit charge HR has stopped working too. It started 3 weeks ago when it stopped syncing. Now it just dies hours after a full charge. What's going on?
05-19-2017 23:58
05-19-2017 23:58
Hi,
My Fitbit charge HR 2 has also died on me after less than a year. After even charging it fully, it is now non-responsive. Can anyone assist?
05-29-2017 05:39
05-29-2017 05:39
Hi there @Firdaus and welcome aboard to the Fitbit Community @cyperalvino. Make sure your trackers are receiving a proper charge.
Dust and debris can accumulate over time and prevent a charge. So clean the charging contacts on the back of your tracker to ensure they stay bronze or gold in color. You can use a toothpick or a toothbrush with rubbing alcohol. Make sure not to scrape the contacts with a wire brush or anything metal, since this can damage the plating and cause corrosion. If you use a toothbrush, dry with a cloth or tissue before charging.
Possible causes for this, is the USB port or outlet might be faulty. So If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can review if the tracker isn't connected securely to the charging cable too.
At last and if the previous suggestions has not resolved the issue, try with a restart. For this I recommend to take a look at this post: How to restart your Charge 2?
Keep me posted how it goes. I'll be around!
07-27-2017 22:59
07-27-2017 22:59
I tried many way to do notification for my S8 and fitbit blaze but still fail.. Can u guide please, I tried uninstall and also. Delete the account but still the same
08-03-2017 07:05
08-03-2017 07:05
Hello @Annabdol, good to see you here in the Fitbit Community.
I'm happy to post that the Samsung Galaxy S8/S8+ has just been added to our official supported devices list.
However there are still a few things being worked out to make sure of its full compatibility, so some users might still have issues with the pairing process or with notifications.
If you are having issues with notifications, please give our troubleshooting tips a try if that is the case.
Hope this helps, see you until the next one!
08-07-2017 02:50
08-07-2017 02:50
I have a fitbit surge and I like to change the strap/band.
May I know where is can get it in Singapore and will they help me to change it?
Thank you.
09-11-2017 15:24
09-11-2017 15:24
Hi i bought a fitbit alta a few months ago and now the battery only lasts 1 days before it wrnt completely flat. Is there a service center where i can send to fit it in Singapore ?
09-11-2017 21:00
09-11-2017 21:00
09-11-2017 21:05
09-11-2017 21:05
09-20-2017 00:30
09-20-2017 00:30
I just bought my HR altar I think 2 weeks back. I did insanity the following day and it actually manage to track it as an aerobic activity. However subsequently when I did any exercise be it insanity or weight lifitng it only records my Active minutes and does not record it as an aerobic activity.
I tried many of the fixes I see online like restarting it or wearing it a little tighter so that it has a nice contact on my wrist. I would like to know if there is any other fixes or if there is smth I did wrongly? Is it cause I'm not moving my arms a lot that's why it does not recognise as an aerobic exercise?
P. S I do sweat a lot (i mean a lot) during my workouts so I'm not sure is it because of that that is hindering the tracking. I wear the altar 1 finger above my wrist when I work out. Some time during the exercise I check my HR from time to time. Most of the time it shows my heart rate but at times it just shows blank dashes.
Thank you very much for the help
11-16-2017 01:39
11-16-2017 01:39
I bought a Charge 2 from Courts on 3 Oct 2017. It stopped working last night. So my sleep and activities since then were not tracked.
Where can I get it service or an exchange?
Thank you.
11-16-2017 23:24 - last edited on 11-23-2021 09:44 by AndreaFitbit
I got my fitbit changed at
Exchange Centre Location
- Warranty period is 12 months from date of purchase
- End user must bring along proof of purchase (invoice/receipt) and respective tracker for exchange
Moderator edit: removed personal information.
11-30-2017 22:27
11-30-2017 22:27
Hi Patsychanpf
can you advise if you bought your fitbit from the Mojito Redemption, which is why they allow the exchange ? coz i bought mine from challenger so curious to know how you managed to get your faulty unit replaced.. can you kindly advise ?
12-02-2017 00:05
12-02-2017 00:05
12-06-2017 22:03
12-06-2017 22:03
Go to Mojito to register. They said they will ask for receipt verification - receipt can be from any retail shop in Singapore. And then they will exchange 1 for 1.
I have yet to hear from them although I have registered for a redemption.
