01-25-2016 02:04 - last edited on 09-06-2020 20:15 by MatthewFitbit
Hello,
First of all, I just want to say that I have really enjoyed having my Fitbit for the last 3 weeks, its been great fun tracking steps against friends and family. This is the main reason why i'm so frustrated as I love wearing the fitbit!
The fitbit started by displaying the wrong time - I then went through the relevant steps and it worked again.
It then worked for another 3 days. Before doing the same thing again. However this time, after following all the relevant steps to get it to work. The bluetooth is now broken and it won't connect to my phones bluetooth (This does work as tested on other bluetooth devices).
I'm not sure what is left to do - should I get a replacement?
01-26-2016 08:58 - edited 01-26-2016 09:00
Hey there @Oompy! Welcome to the Fitbit community!
It's great to hear that your taking advantage of your Fitbit device, allow me to help in order to get your tracker syncing again I recommend you trying the following steps:
Hope it helps! Keep me posted :D.
04-27-2016 09:34
04-27-2016 09:34
I'm in the same spot as the original poster. I went through the list of steps listed by MaginFitbit and none of them worked. When I got to the last one and tried to set up my device as new, neither my computer nor my iPhone can find the Charge HR. I'm really frustrated with this as I really enjoyed using my Charge HR. Any other help or is my tracker done?
06-06-2016 09:25
06-06-2016 09:25
Welcome to our Community @n_endless_waltz! Thanks for stopping by! I'd like you to make sure your Internet and Bluetooth connection are working properly on your iOS device. Also, make sure you have updated your iOS App to the latest version and that you are following the steps provided by @Odyssey13 here.
Hope this helps, let me know how it goes!
06-17-2016 06:43
06-17-2016 06:43
Hello,
I have been using my fitbit flex for some time now and I love using it. It keeps me motivated. However, the bluetooth no longer works. It will not sync to my phone or computer. I have followed the steps listed in this thread, and have even reinstalled the app. Nothing works. The computer and my phone both cannot even find it. Does fitbit replace them if the bluetooth breaks? What do I do?
06-19-2016 05:50
06-19-2016 05:50
Welcome to our Community @Starlamb! Thanks for stopping by! I'd like to know if your Flex is charging correctly? You always need to make sure you're not experiencing battery issues since this can affect your tracker from syncing to your account. You can try to clean the contacts by following the steps provided here. Also, I'd like to know if you're receiving any error message when trying to sync your tracker to your mobile device and computer?
Keep me posted!
06-20-2016 12:23
06-20-2016 12:23
Hello,
My fitbit is working correctly. My silent alarms work, step tracking works, sleep mode works, it charges fine. When I try and sync, both the computer and cell phone cannot find it. I don't get an error message. I get a message saying to ensure my fitbit is working and make sure it is close by. I am always within half a foot of the phone and computer when trying to sync.
06-20-2016 13:10
06-20-2016 13:10
Hello - Very interested in follow up on this post topic. I'm having all the same issues and have completed the same trouble shooting steps as Starlamb and WhistlerWarrior. Neither my iPhone or Surface Pro 3 recognize my Charge HR bluetooth. Battery is loaded. Unit is tracking steps, HR, etc. just fine but not syncing. Unit never goes in the shower or pool or submerged in water - just hand washing and such. I work hard and play hard so it does get banged around a bit at times but nothing major preceeding this sync issue. Only thing to add is that my clock is off by about 3 hours (date is ok).
Looking forward to see proposed solutions. Thank you Moderator for your attention in this matter.
(Tried Fitbit Help chat but website link was not working. Next step will be a call but hoping to see forum comments first.)
06-22-2016 04:59
06-22-2016 04:59
Thanks for the update @Starlamb! This is really weird...I'd like to know if you have make sure your tracker have enough battery? Also, have you tried setting up your tracker as a new device by following the steps provided here?
Welcome to our Community @Stonie1! Hope you're doing great! I'd like to know if you're seeing any error message when trying to sync your tracker to your Dashboard? You can try following the steps provided in this thread.
06-22-2016 06:22
06-22-2016 06:22
06-23-2016 05:10
06-23-2016 05:10
Hey there @Stonie1 thanks for the update! So glad to know everything is now working as it should my friend. I'd like to invite you to our Discussions board which is the perfect place to make new friends and share your interests here at Fitbit.
Have a great day!
06-23-2016 17:10
06-23-2016 17:10
Hi Meylin,
My fitbit is fully charged, and I have tried setting up as a new device. No luck.
06-23-2016 18:05
06-23-2016 18:05
I am in the exact same boat. My Charge HR worked great for months, never had any issues. Then Yesterday it decided to stop syncing and wont connect to either my phone or my laptop (tried fitbit connect as a suggestion in troubleshooting) but nothing is working.
06-23-2016 18:23
06-23-2016 18:23
06-23-2016 20:57
06-23-2016 20:57
I am also having this problem tonight. It's been syncing oddly since the last update, but now it says tracker not found when it's on my wrist 3 inches from my phone.
06-23-2016 21:44
06-23-2016 21:44
06-23-2016 22:04
06-23-2016 22:04
I have been having the same issue, I tried all of the above suggestions and none of them worked. I did a re-set and it worked for about 8 hours and now it won't sync again. I started having problems 2 days ago when my time was off by 30 minutes. the time fixed itself but it hasn't synced properly since and now it won't sync at all.
06-23-2016 23:36 - edited 06-23-2016 23:37
Having the same issue as the above users. Tried with both my Oppo F1f and Samsung s6 edge. My FitBit Charge HR connects thenstright away displays ''Bluetooth Issues".
I'm guessing this is a now a known issue. Any ideas when it will be fixed?
06-24-2016 06:32
06-24-2016 06:32
06-24-2016 09:00
06-24-2016 09:00
