01-25-2016 02:04 - last edited on 09-06-2020 20:15 by MatthewFitbit
Hello,
First of all, I just want to say that I have really enjoyed having my Fitbit for the last 3 weeks, its been great fun tracking steps against friends and family. This is the main reason why i'm so frustrated as I love wearing the fitbit!
The fitbit started by displaying the wrong time - I then went through the relevant steps and it worked again.
It then worked for another 3 days. Before doing the same thing again. However this time, after following all the relevant steps to get it to work. The bluetooth is now broken and it won't connect to my phones bluetooth (This does work as tested on other bluetooth devices).
I'm not sure what is left to do - should I get a replacement?
11-15-2016 04:50
11-15-2016 04:50
11-15-2016 06:31
11-15-2016 06:31
11-15-2016 07:23
11-15-2016 07:23
11-21-2016 23:52
11-21-2016 23:52
The same thing has just happened to my Charge HR. The bluetooth seems to have given up. I have restarted several times, and deleted it from the app, but now I can't reinstall because my iphone can't see it.
This is my third Fitbit and I depend on it.
What should I do? It must be a known problem given this forum!
11-22-2016 00:42
11-22-2016 00:42
hi i have a chargehr and it stoped syncing so i tried unpairing it and now it can not be found by my computer or my samsung galagy s5 i have tried everything on the list even uninstalled the app and reinstalled nothing is working only had it since june any more sugestions
11-23-2016 11:10
11-23-2016 11:10
11-26-2016 04:06
11-26-2016 04:06
12-21-2016 21:33 - edited 12-21-2016 22:19
Got a replacement due to bubbling issues. Was able to connect the first time. Then I had to reverse to my old one to capture data and then removed old device from fitbit app and reinstalled the new one. Would not sync. Then noticed that it wasn't pairing on the Bluetooth on my mobile and the connect on the website was failing too. So isolated it to the replacement Fitbit. Followed instructions above and it only worked after I did the restart of the Fitbit 3x. Hold it for 12 sec until you see the Fitbit version appear with the Fitbit logo 3times. Then went into Fitbit app to setup the device, code popped up and "connecting to fitbit appears". This usually dragged so I left for 20 min. When I returned to look at mobile phone, it is now synched up and is recognized in the Bluetooth screen (it wasn't prior to the restart). Have not installed the new IOS 10.2. Going to wait a week until I know this is stable. I do believe the Fitbit just needs a very clean reboot. Use her link above on how to restart your fitbit.
12-21-2016 21:39 - edited 12-21-2016 21:43
One more add:. Prework:. Prior to restarting the Fitbit, I cleaned up Apple phone by removing any paired setup in the Bluetooth device list (go to settings, Bluetooth on your iPhone ). Then restarted the iPhone and then went into Fitbit to add a device.
12-28-2016 17:58
12-28-2016 17:58
My Blaze is not displaying the bluetooth link in the settings. It appears one minute and I can turn it on, but then it turns off by itself and disappears out of the settings. Please Help!
01-19-2017 04:31
01-19-2017 04:31
I have tried all these things and various other suggestions in a sync problems page, restarting, resetiing, uninstalling app, reinstalling app, forcing apps to stop and restart, clearing cache and data, restarting phone, turning bluetooth on my phone on and off, you name it, i have tried it.Nothing i do makes my bluetooth on my phone see the fitbit charge hr device. I have successfully paired my phone to my laptop so both those devices are wiorking. My laptop cannot see the charge hr either.
this worked yesterday, i managed a sync after pairing when my sister set it up for me the first time.
I am feeling seriously frustrated and cannot get any local support in South Africa.
What more is required? I think the bluetooth on the fitbit charge hr just doesn't work. what now? how do i check/fix that? Please help...
thanks
02-08-2017 00:57
02-08-2017 00:57
Mine is doing this too!
I have:
Reset fitbit charge hr
Uninstalled and reinstalled app
Restarted phone
Unpaired device from bluetooth
Unpaired from fitbit app
Now I cannot see it as an avaliable Bluetooth device nor can I readd as it cannot be located / found
Really disappointed
02-12-2017 14:08
02-12-2017 14:08
I've had the same issue. I've tried all the suggested restarts of the device and on both the PC and the phone it no longer appears to be finding the device as if Bluetooth all of a sudden stopped working. I noticed the issue when it seemed the battery was barely making it through the day, then all of a sudden seemed to also have the wrong date and time. Feel like I've tried all I can at this point and about ready to throw it away. Is there any way I can take it somewhere locally to be serviced? We bought it from a T-Mobile store, but it is just over a year old so doubtful it's under any sort of warranty.
02-13-2017 00:46
02-13-2017 00:46
Hi! @MaginB So I have had the same problem and I tried setting up as as new device but it still won't sync up through the Bluetooth. It is saying it is not picking it up. What else is there to do. I tried all that you suggested..
02-27-2017 10:57
02-27-2017 10:57
You likely have multiple CHARGEHR or CHARGE bluetooth connections on your phone causing confusion esp if you are getting errors connecting.
Assuming you have an iPhone. Do the following in this order:
If you encounter issues, start again. Likely you missed a step. Goodluck.
02-27-2017 10:58
02-27-2017 10:58
Check out my posts
02-27-2017 11:06
02-27-2017 11:06
03-06-2017 03:07
03-06-2017 03:07
I have the same problem. My charger hr bluer ooh appears to be broken and will not sync with my device. It is definitely not the device. The tracker is fully charged. Please advise next steps
03-25-2017 21:19
03-25-2017 21:19
I'm having the same problem.
the Fitbit worked fine for about three weeks, then suddenly I find that it has not been tracking me for a couple of days. I first expected user error, but after trying all the suggestions on this board, I still cannot connect with Bluetooth.
03-31-2017 08:27
03-31-2017 08:27
I have tried all of the recommended steps and none are working for me. It's as if my Fitbit HR Bluetooth signal just stopped working. Urgh....
