02-24-2016 16:44 - last edited on 09-06-2020 20:15 by MatthewFitbit
02-08-2017 11:54
02-08-2017 11:54
Thanks for getting back to me @yelword! Reading that you're now back on track was like a ray of sunshine. Feel free to post back!
On a different note, I encourage you to visit our Discussion boards. In there you'll find lots of interesting topics and you'll make hundreds of Fitbit friends. It's a lot of fun!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
03-13-2017 15:05
03-13-2017 15:05
Will the reset mentioned in this thread work for the Fitbit Flex too? It will no longer sync my sleep info.
03-14-2017 15:20
03-14-2017 15:20
@Nana65 welcome aboard! The restart for your Fitbit Flex is the following:
Just as a friendly reminder, please make sure you post your inquiries related to your Fitbit Flex in its right board, since this is the Charge HR board. In the correct board you'll be able to find more relevant info related to your tracker. Also, you'll be helping us to keep the community an organized place for everyone. Thanks for your understanding!
Catch you later.
05-27-2017 13:08
05-27-2017 13:08
I've tried restarting the band, turning off bluetooth, uninstalling the app, restarting the phone, etc. Have I missed a step? It tracked everything for 2 days and nights and now it's a fight to get it to sync steps. Ideas?
05-29-2017 13:17
05-29-2017 13:17
@DianneT13 thanks for joining us in this thread and for troubleshooting beforehand! That definitely doesn't sound like normal behavior. If possible could you please attach a screenshot of what you're describing please? That would give me a better picture of what the situation is.
Has this happened before? How many times did you restart your tracker? Sorry to answer your post with more questions, but I'd really like to have a clear picture of what the issue is.
In the meantime, you might want to set up your tracker as a new device (do not unpair your tracker to do this). Please follow these steps to go through the set up process again. Hope this helps, keep me posted!
05-29-2017 14:17
05-29-2017 14:17
05-30-2017 13:12
05-30-2017 13:12
@DianneT13 it's lovely to hear back from you! Check out this post with further instructions on how to connect your Fitbit and MyFitnessPal accounts. I really hope this helps. I'll keep my fingers crossed too for this one!
Let me know how it goes!
09-02-2017 23:01
09-02-2017 23:01
For the last 3 days my Fitbit hr is not syncing my sleep help please
09-24-2017 14:01
09-24-2017 14:01
Hey there @Mimiperks123, welcome aboard! Have you tried restarting your tracker already? If you haven't done so already, I suggest doing the following:
After the restart, I recommend giving it a try and test it for next morning. Just out of curiosity is this happening from both a mobile device and your Fitbit.com Dashboard? Do let me know!
I'll be looking forward to your new comments!
11-21-2017 11:02
11-21-2017 11:02
I have a brand new Charge HR and it is showing that I go to sleep every night at 4:00 AM plus/minus a few minutes and I am actually going to bed at 11:00 PM. How do I get my HR to track my sleep correctly?
Thanks
12-05-2017 14:11
12-05-2017 14:11
@wxpeter thanks for taking a break from stepping to visit the community! That definitely doesn't sound like normal behavior. Make sure that you are syncing your tracker properly. Check out this post with steps on how to sync your tracker.
I also suggest attempting a restart by doing the following:
Also, please note that although your Charge HR autodetects sleep and it's designed to know when the device is off your wrist, occasionally it may record a sleep log when you aren't actually asleep. You can delete this sleep log on your dashboard. Click here for instructions on how to do so.
I really hope this helps. Keep me posted!
12-17-2017 09:38
12-17-2017 09:38
I've had this problem for the last few days. I have deleted the app and reinstalled.
I have linked it to USB and held button etc and restarted the tracker. It recognises everything else but not sleep. Tried the community forum online chat and 27 people ahead of me and gave up...very frustrating
12-17-2017 10:53
12-17-2017 10:53
12-20-2017 13:07
12-20-2017 13:07
@map57 & @wxpeter thanks for the follow up guys! I certainly appreciate your reports about this; therefore, I'd like to request screenshots of your Dashboard where your tracker isn't recognizing sleep. This will definitely help me get a better pic of the situation.
In the meantime, I suggest taking a look at this article: How do I track my sleep?
I'll be looking forward to your replies!
06-16-2018 15:12
06-16-2018 15:12
I couldn't get my fitbit to track my sleep until after setting up the device I went back into set up a device on my phone and paired it. First you click on the box at the top right in the dash board. Then go to set up a device, follow the instructions to replace the device, then your fitbit will give you a code which you type into your phone and you enter next about ten times and your done.
06-19-2018 05:05
06-19-2018 05:05
It stopped syncing sleep a week ago
11-23-2018 03:20
11-23-2018 03:20
I plug my Fitbit in and I press the button for 10-12 seconds but I never get a logo and the version number to pop up. Doesn’t matter how many times I do it. I bought this within this year I’m pretty sure so I’m frustrated that it’s already not working properly.
11-29-2018 00:54
11-29-2018 00:54
Thank you! I had two problems, one with my sleep no longer showing correctly and secondly that my heart rate stopped showing at all. I did the restart as you advised for the other user's sleep issue and in doing so, my heart rate record instantly resumed. I'm only using my Fitbit for these two functions so I'm now hopeful that this simple restart proves to be the key when I sleep tonight. Much appreciated!
12-02-2018 16:16
12-02-2018 16:16
Updating to confirm that the reboot advice also fixed my sleep record.
12-30-2019 14:38
12-30-2019 14:38
Apparently the thread you have listed tells me access denied. Any idea how and why my sleep tracker stopped?
id love to read what you were trying to lead to.
