01-08-2016 08:22 - last edited on 09-06-2020 17:10 by MatthewFitbit
01-08-2016 12:01
01-08-2016 12:01
No, it probably won't. You need to add it directly through the app, not through the phone's Bluetooth menu.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
01-08-2016 08:30
01-08-2016 08:30
I saw that someone posted that you need to have notifications enabled in order for your charge to connect to bluetooth. I have already done that and it still will not show up and connect. I have tried turning bluetooth off and on so that it will pick it up and that doesnt work either.
01-08-2016 12:01
01-08-2016 12:01
Mike | London, UK
01-08-2016 12:44
01-08-2016 12:44
01-08-2016 13:07
01-08-2016 13:07
Hi Michele @Meechy517. Here is the iOS troubleshooter for your to try:
If all fails, I would contact the Support Team: http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Hope this helps. Please let us know how it goes.
TW
____________________________________________________________________________
(If this tip solved the problem for you, please mark this post solved, as this will be helpful to other users experiencing similar issues.)
12-28-2016 11:51
12-28-2016 11:51
12-28-2016 12:53 - edited 12-28-2016 12:53
Fitbit HR will not sync and is not showing in the Bluetooth Settings of my iPhone 6. Worked fine for 18 months until this morning.
I tried all the steps:
Restarting the Fitbit
Force Quiting the Fitbit App
Restarting the iPhone
Turning Bluetooth on/off
etc. (as per the instructions here on the site)
I also tired to sync it with my iPad. It also doesn't show in that device's Bluetooth Settings.
Suggestions?
12-28-2016 15:22
12-28-2016 15:22
It will never show in your phone's bluetooth settings unless you have notifications enabled in the app. Otherwise a bluetooth connection only lasts as long as it takes to sync. Have you tried uninstalling the app, rebooting the phone and then reinstalling the app? Also, did you recently install an iOS update?
12-28-2016 17:36
12-28-2016 17:36
It has always been there until it stopped synicing today.
01-02-2017 16:27
01-02-2017 16:27
Had the same problem - see if this works (worked for me).
1. Open the Fitbit application
2. Select 'Account-->Surge-->Notifications' (I have a surge but I suspect there will be similar options for other devices)
A popup asks you to pair device to phone. Select 'Yes'.
Surge appears under the bluetooth option.
Hope this helps.
01-05-2017 07:29
01-05-2017 07:29
A warm welcome to our new friend @GSinha! Thanks a million for sharing what worked for you! This is what the Community is all about; sharing knowledge and best practices so we can learn from each other. @bygeorge please try what @GSinha suggested and then post back with the results, I'll be around!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
01-29-2017 19:53
01-29-2017 19:53
None of the options offered in the community post worked for me. My charge two still won't show up under my blue tooth setting on my phone
01-30-2017 12:54
01-30-2017 12:54
@Lexicat2006 thanks for joining us! That's pretty weird. If you've tried all troubleshooting posted above to no avail, then I recommend contacting our Support Team for further assistance. They definitely have the proper tools to take a deeper look into your tracker's behavior. Mention them all the troubleshooting steps you've done so far to fix it. This shall help them to give you a quick follow up!
02-21-2017 04:03
02-21-2017 04:03
Thank you for this suggestion. I have followed your instructions and it has worked for me.
02-21-2017 15:27
02-21-2017 15:27
@mdaniels thanks for joining us! Reading that the instructions worked was like a ray of sunshine. I appreciate you took the time to let me know that it worked for you!
I encourage you to visit our Discussions section in the community. In there, you'll find lots of interesting topics and you'll find hundreds of Fitbit friends!
03-18-2017 20:30
03-18-2017 20:30
I do not see the "Surge" option under my Account settings. Is there anything else i can do to try to pair my device to my phone?
I have tried restarting my phone, re-installing the app, reseting my FitBit, turning off/on my bluetooth.
This is my 3rd Charge HR to malfunction. Any help would be appreciated.
03-20-2017 14:41
03-20-2017 14:41
@Ray15 thanks for joining us in this thread! Just like @MikeF mentioned earlier in this thread, you need to add it directly through the app, not through the phone's Bluetooth menu. I suggest giving a try to the troubleshooting steps @GSinha posted above. Let me know how it goes, I'll be around!
04-02-2017 01:55
04-02-2017 01:55
Hi, mine wasn't syncing to my new iPhone and I'd tried everything. What eventually worked was going to settings, selecting the Fitbit app, turning off the access to Bluetooth thing and then turning it back on, synced straight away! Hope this helps someone 🙂
04-03-2017 13:53 - last edited on 04-10-2017 13:38 by MariamV
Me too!
Moderator edit: format
04-04-2017 17:21
04-04-2017 17:21
I've had the same problem.
When I contacted Fitbit support, I was told my device wasn't paired with my account (I thought if I tried to set it up again that it would sync.) I tried everything that was suggested, sent it screen shots, etc. I was told that my 2-year old Fitbit was no longer under warranty and that they couldn't help me. I was offered 25% off on another Fitbit, but I'm rethinking my loyalty to Fitbit, since I would expect my device to last for more than 2 years - apparently in the U.S. the limited warranty is for 1 year. It's too bad. I've had a Fitbit for at least 5 years and really liked it, but will probably try another device.
