01-02-2017 15:23
01-02-2017 15:23
I'm making homemade soup with veggies, mushrooms, beans and a chicken stock base. Is there an easy way to log the component ingredients on a per serving basis? Tips and tricks out there for that? Any insights would be helpful. Thanks!
01-02-2017 17:23
01-02-2017 17:23
When I was logging food I would use MyFitnessPal it can link to your FitBit food log and import the totals for each meal. You can build up a "recipe" from the parts in it and set your "serving size". Takes a little bit of work to setup the recipe at first but once it is done its available to use anytime.
It will tally up the carbs, fat, protein etc. from the constituent parts, or you can override it and just enter in the carbs, fat, etc. yourself.
01-02-2017 19:16
01-02-2017 19:16
Weigh ingredients as you go then measure by cup or weight when you're done. I think myfitnesspal is a good option. I use an old piece of software (Fitday) that I own to do this.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
01-03-2017 06:40
01-03-2017 06:40
THanks! I'll give that a try.
