02-27-2014 11:10
02-27-2014 11:10
How do you input a recipe and save it into individual serving portions?
03-07-2014 07:25
03-07-2014 07:25
I would recommend using MyFitnessPal for your food logging (it syncs directly into your fitbit account). It has a recipe calculator and you can enter in how many servings a recipe makes and it calculates it all and saves it for you.
03-07-2014 07:25
03-07-2014 07:25
03-18-2017 10:53 - edited 03-18-2017 10:56
@Benois1 wrote:How do you input a recipe and save it into individual serving portions?
https://recipes.sparkpeople.com/recipe-calculator.asp
You can enter individual ingredients, then enter the number of servings. It will calculate all the nutritional info from there for each serving.
Then when you add a custom food to fitbit app just enter that info and choose 1 serving for serving size.
