12-07-2016 18:16
12-07-2016 18:16
I bought some Apple & Cinnamon oatmeal, and I just ate a packet. It tastes way mooshy. It needs something sturdy to it, or something crunchy added. I also wouldn't mind being able to add chocolate to the oatmeal or something
05-02-2017 19:08
05-02-2017 19:08
Hi there,
I love to buy organic plain oatmeal then after adding my water, I dice up a crispy apple and drizzle with local honey. It's delicious!! Good luck.
05-03-2017 10:59
05-03-2017 10:59
What a busy guy does: I buy instant oatmeal in the big container. During the weekend, I'll package up 1/3 cup oatmeal, about 1/4 cup walnuts and about 1/8 cup dried raisins. My preference is to use the mini snack bags, but sandwich bags work fine as well. I'll take all of these pre-packaged breakfasts to work and keep in my drawer. Grab my cup....pour contents in.....cover with hot water from the water machine and wait 5 minutes! Tasty, naturally sweetened and a little crunchy! Cheers!
05-04-2017 14:59
05-04-2017 14:59
When I eat my oatmeal I add 1/4 cup of granola to it. Sometimes I add strawberries, blueberries, or what every fruit I have on hand. I might add raisins, or walnuts, almonds all depend on what I have on hand
05-05-2017 05:04
05-05-2017 05:04
I cook Steel Cut Oats in the morning. I add a quarter chopped Apple, sunflower seeds and a little bit of cinnamon and I'm good to go. When nectarines were available I would use that. Most times I use my own on homemade granola. By chopping up pecans, walnuts, almonds, and maybe some other nuts if available and sunflower seeds together, putting them in a Ziploc bag and using that as a topping for my oatmeal. I also switch up with using blueberries, BlackBerries or strawberries when available. Some kinda good! I'm looking forward to trying some of those other things such as peanut butter and pomegranate Aprils. Seems like it will be good.
05-05-2017 06:46
05-05-2017 06:46
Returned to my old standby this morning of steel cut oats (5 minute variety), cranberries, nuts (sunflower seeds this time), and cinnamon.
I generally prefer dried fruit in warm dishes like oats, but fresh berries of any kind with a mixed with a bit of plain greek yogurt make a great pairing with a warm oats concoction.
Scott | Baltimore MD
05-05-2017 10:14
05-05-2017 10:14
If it is mooshy, you have to add more water. I generally fill up an extra few ounces to keep it from being like that.
05-09-2017 10:56
05-09-2017 10:56
Feed it to a cow then once fat enough cut into steaks, sausages, beef roasting joint etc - its the only way to make oatmeal taste good
05-09-2017 12:40
05-09-2017 12:40
@ashwolve wrote:Feed it to a cow then once fat enough cut into steaks, sausages, beef roasting joint etc - its the only way to make oatmeal taste good
Ha! That answer is almost worth marking as an "Accepted Solution." But I won't since I do like oatmeal -- as well as steaks, sausages, etc.
05-09-2017 12:49
05-09-2017 12:49
@Baltoscott you did say better but you can have both lol beef and oat casserole , steak and egg oatmeal or Salisbury Steak, to name but a few
05-11-2017 08:34
05-11-2017 08:34
@ashwolve wrote:@Baltoscott you did say better but you can have both lol beef and oat casserole , steak and egg oatmeal or Salisbury Steak, to name but a few
I add a spoon of peanut butter, or 1/2 cup blueberries or any fruit you like, or spices that u like or make oatmeal cookies. hope this helps
05-12-2017 14:40
05-12-2017 14:40
Instant oatmeal is not very good. It took me a little while to come around to oatmeal too, but I've found a way to yum it up while reaping all of its beautiful benefits:
Definitely ditch the instant oatmeal for the old fashioned oats (store brand tastes just as good as name brand). I make a 1/2 cup of oatmeal with a 1/2 cup of almond milk. Then, I add a drop or two of vanilla flavoring, and a pinch of stevia sweetener. Mix it and heat it up, then serve with chopped pieces of banana. It is delicious!
05-15-2017 01:37
05-15-2017 01:37
Im always adding one table spoon of sweetener in it.
Or 10-15 grams of honey.
Ill mix 30 to 100 grams with water and put it in the microwave for about one and a half minute.
05-16-2017 11:06
05-16-2017 11:06
Avoid instant. It's too processed. DO USE STEEL CUT! It's the least processed. Least processed = more nutrients. And you can make it before bed for the morning after. It soaks up the water (or milk) overnight. For flavor that isn't loaded with sugar, add a small amount of raisins and/or banana, and/or apricot, and or dried cherries/cranberries. And a little cinnamon goes a long way. 🙂
05-16-2017 16:03
05-16-2017 16:03
You could add dried cranberries and almonds or even dark chocolate if you had to have it. You can pretty much add anything to it. I like to cook mine so its thicker, I can't stand runny oatmeal. Actually, to ge honest I don't care for it at all. I stick to smoothies and eggs for breakfast. lol!
05-21-2017 03:50
05-21-2017 03:50
it taste beter with fruit
05-22-2017 13:24
05-22-2017 13:24
In the morning I have rolled oats (not cooked) and put in half scoop vanilla whey protein. little bit of milk and frozen berries fruit eat like a cereal. the vanilla whey helps make oats taste better and process good recipe for slimming down abs. try it out its great
05-23-2017 15:12 - edited 05-23-2017 15:17
Overnight cold method: Use a package of regular oat (non-sweeten, you can also use rolled oat), add half a cup of milk (1% or 2%), half a cup of water, half a cup of frozen berries, 5oz of banana. Throw this in the fridge overnight, add a scoop of vanilla whey protein powder before serve. This is super addicting and great with macros.
Hot Method: Use 1 package of oats or ~1oz to a pot, add 1 cup of milk or water (or mixed). Cook this until desired textures, add 2 Tsp of Peanut butter, 1 scoop of chocolate whey. This is a great recipe if you want to put on some weight.
05-29-2017 16:54
05-29-2017 16:54
I usually use the store brand's 1 minute oatmeal in the big container. I place a 1/2 cup of it into a plastic lidded container, which I take to work, adding a little cinnamon to it. (I leave for work before my stomach can take anything more than coffee.) I add either a small container of unsweetened applesauce, or about 1/8 cup of sugar-free maple-flavored syrup to it. Or, perhaps a small amount of either raisins or dried cranberries (no more than a tbsp) gets added to it. Depending on what I've added, I might add no-calorie sweetener to it as well. When I get to work, I add just a little water -- not nearly what the recipe on the carton calls for -- and cook it in the microwave for about a minute. Now, I've loved oatmeal since I was on Gerber's Baby Oatmeal, so it sits well with me.
When we're on trips, I steer clear of the flavored packets of instant oatmeal. They have too much sugar for my blood (literally). There are packets that do not contain any sugar, and those are what I head for. On our last trip, the place we stayed did not have the unflavored packets, so I went to the local grocery store and bought some. They aren't as good when you're in a hotel room with no applesauce, raisins or cranberries to dress them up. But they'll do, in a pinch!
Donna
T2D
06-04-2017 05:34
06-04-2017 05:34
I felt like a change and bought oatmral with ancient grains. It is really yummy! I just have it with soy milk and love the nutty sort of grain taste. It was a good purchase!
Helen | Western Australia
06-04-2017 05:40
06-04-2017 05:40
