07-12-2018 09:45
07-12-2018 09:45
There is a place where you can rename a food you log so you can find it better, but when I change the name it then says I can't change the name. Why is there a place to change the name if you can't actually do it
07-12-2018 09:50
07-12-2018 09:50
@EskimoJoe wrote:There is a place where you can rename a food you log so you can find it better, but when I change the name it then says I can't change the name. Why is there a place to change the name if you can't actually do it
It's a global conspiracy.
07-12-2018 09:53
07-12-2018 09:53
That was so helpful I can't believe I didn't think of that myself.
07-12-2018 13:22
07-12-2018 13:22
On the food log right hand side look for edit foods. Under favorites and before foods
Wendy | CA | Moto G6 Android
07-13-2018 07:23 - edited 07-13-2018 07:24
I just edited a food on the phone Andriod only
Also on the web no problem
How are you trying to edit?
If iPhone it could be part of the problem they are aware of and Working on.
Check the iOS forum for updates
07-16-2018 09:22
07-16-2018 09:22
There is no place to do this. Under favorites and before foods is just part of the black bar for the label FAVORITES.
There is no place on the right that allow edit either.
I am doing this on my computer on website.
Dennis
07-16-2018 13:37
07-16-2018 13:37
Have you tried a different browser?
I think you need to contact support so they can look into your account.
Use the help at ther top of the forum.
03-05-2019 13:32
03-05-2019 13:32
When I am on Chrome, looking at the Fitbit Website, I see "Edit my foods" under the Favorites, but when I click on it, it lists only one odd food item that isn't even in my favorites. Most of all the favorites (50 total) are from scanned packages. Are we able to re-name these once in our favorites?
