08-09-2018 12:11
08-09-2018 12:11
Does anyone have any suggestions of a water tracker app that syncs with Fitbit?
08-09-2018 18:22
08-09-2018 18:22
Why not use fitbit? Takes 2 seconds to open app and log a water
Wendy | CA | Moto G6 Android
08-09-2018 18:26
08-09-2018 18:26
I did use to use Plant Nanny. It doesn't sync with fitbit
But you grow plants as you go. It was fun for a while
08-12-2018 02:17
08-12-2018 02:17
I use Hydro Coach. In the free version the ads are annoying but the pro isn't half bad. The reminders help a lot.
12-29-2018 09:25
12-29-2018 09:25
Hi Nezu, does your Hydro Coach sync your water diary to Fitbit app? Im using the pro version of Hydro Coach, and the Fitbit integration permissions are set correctly, but my Hydro Coach stats don't sync.
Also, I can't find a Hydro Coach support link/email.
Thanks in advance for any info.
