in data 08-11-2023 17:39
Hello everyone,
I saw another topic like this that was closed, but not solved apparently.
I am writing to tell you that I partially found a solution, but I would like an update from Fitbit, since the same problem can occur again in future.
Basically, I bought my device mainly for the smart alarm feature, and everything was working so perfectly. The only feature that was annoying me was the constant vibration telling me I was walking a lot in those days, so I tried to disable it (but found out it is not possible) and ended up changing all my goals. By making them hardly reachable I thought that I could have solved the problem annoying me. Not only it did not work, but from that day all alarm vibrations on my Fitbit stopped working.
Today I finally followed the restart and reboot procedures to try fixing the issue instead of returning the Fitbit, and it worked luckily....but software improvements can still be made.
If you experienced the same issue, please drop a comment.
