Right now, The "gray scaled" text isn't visible in the sunlight and forget about it if I'm wearing sun glasses. We should be able to either chose between simple B&W display (eliminating the gray scale) or the ability to adjust the brightness even higher then it  is currently.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
