Yes, additionally the dashboard is not 'touchfriendly' when using tablet devices that can do flash. Many elements of the dashboard are only accessible with a cursor hovering over them - not possible on a touch screen.
Please get rid of Flash. I use my iPad much more than my laptop. I use my iPad when I travel, both for pleasure and business. I will be using my iPad for field work, starting in September.
If you use flash because you lack developer resources to rewrite in HTML5, then how about a user competition. First person (or top vote getter) who writes a dashboard to fitbit's spec wins a tracker or something.
Plus, if the resulting code was open... we could write up all our feature-requests OURSELVES and you could take the ones you like.
I would like the dashboard charts to be displayed in HTML5 canvas and not Flash,
So I can load the charts in mobile devices.
HTML5 charts can be secure if you use the https for the web APIs. Flash is not that much secure either way, given that if the users are not updating the software application it’s a risk. Flash also uses lot of memory, batter power, and doesn’t work in Surface and iPads.
Just another vote of agreement. I use Android and on my home computers Linux, neither which likes Flash very much. Flash can definately be a resource hog, I find sites that have switched over to HTML5 much nicer to use.
To view the graphs on the Dashboard you need Adobe Flash installed. This puts limitations on what browser and platform you can view you result details on. For instance I use my Android tablet a lot for many web activities including checking my Fitbit stats, forums etc. I can see my daily stats but not the graphs for comparison. Adobe Flash isn't supported on Android any longer, not sure the same is true for iPad or not.
Would think the same thing could be accomplished with HTML5
IOS (iPad / iPhone) have never supported Flash. I agree that a different display type needs to be used espcially now that both Android & iOS don't support Flash.
I just signed up for the Premium Tools & really like how they look on a PC. But rarely do I get on a PC and mainly view my Dashboard & Premium Tools on my iPad Mini. Since the iPad / iPhone doesn't support Adobe Flash, there is very little I can see in my Premium Tools. It is very dials appointing. Please revise the graphics on the dashboard & Premium Tools so they don't require a Flash plug in and can be viewed on tablets & phones.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
