Several of your users are requesting that the sleep sensitivity options be increased to at least three. Now we have Normal and Sensitive, but some users are downloading the information and using an average of the two to essentially have a setting between Normal and Sensitive.
I suggest either adding another setting sensitivity or emulating the idea of averaging the two in a software solution.
Thank you!
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
