05-10-2018 18:28 - last edited on 05-13-2018 12:10 by AlessFitbit
Half the reason I upgraded from the Alta was for this feature. I can enter my data in the app but see nothing on the Versa itself.
Moderator edit: title for clarity
05-13-2018 01:53
05-13-2018 01:53
Yes, me too, scroll to the "Today" thing and it's the last feature - as seen in attached pic.
05-11-2018 07:15
05-11-2018 07:15
It will just be on the app. Not on the device
Wendy | CA | Moto G6 Android
05-11-2018 19:25
05-11-2018 19:25
I see info from the app on my Versa. Slide up into the Today app and it shows at the bottom
05-13-2018 01:53
05-13-2018 01:53
05-13-2018 12:07
05-13-2018 12:07
Hi, @anliopard, you will need to enter the information on the app, but once you have logged a period on the app you will be able to get the information on the Today screen of your Versa, as others have noted.
05-16-2018 00:35
05-16-2018 00:35
I see the female track on my computer (I use window) but I don’t have it on my Versa ( I use an android). I know the app for Android will come out later but I have it on my computer. I’m just confused. If it’s on my computer, shouldn’t I see it on my Versa too?
05-24-2018 12:05
05-24-2018 12:05
Yeah, I have that. I was under the impression that there would be a SEPARATE app on the device.
