01-22-2025
16:05
07:58
LizzyFitbit
01-22-2025
16:05
07:58
LizzyFitbit
Hello, what does it mean, Add a tile? The instruction it gives is: Long press any tile to edit your carousel.
When holding down the screen, nothing happens.
Only a circle has appeared suggesting to slide to where this message comes from.
Restarted the device the circle disappeared, the message did not.
I appreciate any advice.
01-26-2025 01:44
01-26-2025 01:44
@Mirella24 could you please try a factory reset? The watch's settings and game progress will be restored. After the watch is back online, could you please tell me the software version on the watch (swipe right from the home screen and swipe to the bottom which should say 'You are playing Season...'. ).
01-23-2025 10:03
01-23-2025 10:03
Hello @Mirella24
Please let us know where you are seeing this instruction. Is it on the Ace device? If so, on which screen do you see it? Is it on the clock face?
01-23-2025 20:05
01-23-2025 20:05
Yes, it is on my son's watch. by swiping right or left on the clock face.
01-23-2025 20:07
01-25-2025 05:20 - edited 01-25-2025 05:23
@Mirella24 I can't find any reference to tiles or your carousel in the Ace LTE Help articles.
@FitbitElli Can you help this user?
Laurie | Maryland
01-26-2025 01:44
01-26-2025 01:44
01-31-2025 18:28
01-31-2025 18:28
I tried the factory reset and everything works as it should, thank you very much for your help!
