It says in the app that you should be able to remove the pin on the device, but I can't find where to do it. There's a pin on the device now and I want to change it to a pattern. How do I do that in the app or on device?
Best AnswerHello @The_real_kate
Access the Settings menu on the Ace LTE device to change the security option from pin to pattern. This article (<-- click link) has the instructions.
