For the Dev Team - Fitbit Ace LTE
ANSWERED
The typo appears in the “Find My Device” feature when the device cannot be located. The incorrect text currently reads:
Couldn’t retrieve location. Device may be in an area that haslow signal.
The issue is that “haslow” should be two separate words. The corrected text should be:
“Couldn’t retrieve location. Device may be in an area that has low signal.”
This small fix will improve readability and clarity for users encountering this message. Please consider addressing this in a future update. Let me know if you need any additional details.
1 BEST ANSWER
Accepted Solutions
Hello @Lurker
Thank you for providing this.
You can actually submit this using the Feedback option in the Fitbit Ace LTE app.
  • Tap on your picture in the upper right of the Ace app
  • Tap on Feedback in the menu that opens
  • Complete the prompts & submit
Although it's likely that you won't receive a reply, the team receives & reviews the feedback reports.
1 REPLY 1
Hello @Lurker
