06-13-2024
06:31
12:18
LizzyFitbit
06-13-2024
06:31
12:18
LizzyFitbit
I turned on screen lock on my son's Ace LTE just to see how it worked and now I can't find a way to turn it off. The app suggests that it can be done from the phone but I can't find a way and I also can't find any resources online to suggest how to do it. My current assumption is I may have to factory reset the device but I'm trying to avoid that if I can.
Best Answer06-13-2024 14:44 - edited 06-13-2024 15:01
Hello @Azhorn7
One of my colleagues, @TechWithBrett , shared the instructions on how to turn off the screen lock. As the message indicated is done from the Ace watch:
06-13-2024 12:09 - edited 06-13-2024 12:22
Hello @Azhorn7
I take it that you used the Settings menu > Device Control on the Fitbit Ace app to setup the screen lock with a pin.
I'm going to check with my colleagues to see if anyone has seen a way to turn off screen lock.
Best Answer06-13-2024 13:38
06-13-2024 13:38
Best Answer06-13-2024 14:01
06-13-2024 14:01
Hello @Azhorn7
Thank you for confirming how you set up the screen lock.
Just to confirm: When you went back into the Settings menu on the app to try to disable the screen lock in the Device control section, the message there said to turn it off from the watch. Would you please be so kind as to provide a screenshot of the message you see in the app?
Hello @Azhorn7
06-09-2025 05:01
06-09-2025 05:01
Mine keeps going back to Screen lock, and my son forgot his code, so we are completely stuck and nothing works…super frustrating
Best Answer06-12-2025 10:15
06-12-2025 10:15
Hello @Auds238
This help page has the instructions on what to do if the code is forgotten (<-- click link).
Basically, you will need to factory data reset the Ace LTE. Once your son logs back into his Ace LTE, all his progress should return.
If you have any problems with the factory data reset, you can contact Ace Support (<-- click link). Complete the prompts until you get the option to chat or call.
