12-28-2016
23:25
14:34
AlessFitbit
12-28-2016
23:25
14:34
AlessFitbit
Hi Everyone,
As I flip through my watch, I see some symbols that I do not know the meaning of... is there a photo of the symbols that tell me the meaning i.e a guide that I can refernce ?
Like what is the flame with a number under it?
or the lighting bolt? or the man with his leg bent and arms up?
Christina
Moderator edit: format and title for clarity
08-06-2021 20:20
08-06-2021 20:20
Hi everyone,
Most of the icons you can see on your Fitbit will be found here: How do I navigate my Fitbit device?
Additional symbols for stats including sleep, exercise, water and food intake, weight, and menstrual health are here: How do I track my activity with my Fitbit device?
If you have questions about any of those or any other let us know. 😉
12-29-2016 00:44
12-29-2016 00:44
Flame is calorie burn
Heart is for Heart rate
lighting bolt is active minutes
Shoes are steps
Stairs are floors
guy is your 250 and hour
dont know what to call the last symbol but it has MI in it which is your Miles
Wendy | CA | Moto G6 Android
12-29-2016 17:17
12-29-2016 17:17
Thanks Wendy, under my running man it says the number 30...is that for number of minutes it took me to reach my 250/hr? It can't be number of hours, right? As there are only 24 in a day? Thanks in advance!
12-29-2016 17:38
12-29-2016 17:38
Does it say 30/250? It means 30 steps of the 250 are done.
12-29-2016 17:55
12-29-2016 17:55
I only have my tracker set up for 9am-5pm, and at 7.15 this evening it said 30, and now it says 250 (at 7.55pm) -does it continue to track after the specified hours?
12-29-2016 18:13
12-29-2016 18:13
I started using mine today too. It appears the counter rests at 250/250 after the hourly goal end but the steps for the day counter keeps recording.
12-30-2016 16:21
12-30-2016 16:21
What is 250/hr mean? And what does active minutes mean?
12-30-2016 16:41
12-30-2016 16:41
They are the same symbols that are used in the app.
12-30-2016 17:01
12-30-2016 17:01
I've noticed that it does continue to count your hourly steps on the device (up to 250) when outside of the hours you chose, but only those you picked will show up in the active/hours per hour tile. I still think showing it is motivation. 250/hour is the number of steps they want you to take per hour (it stops showing you, once you reach 250 as well, no matter how many you get in the hour).
01-06-2017 11:17
01-06-2017 11:17
Found this! And for everyone else who needs it
01-07-2017 14:42
01-07-2017 14:42
Thank you
01-26-2017 07:47
01-26-2017 07:47
Should all those icons be on my fit bit? I only see the 250 steps per hour on my app. as well as the stairs.
01-26-2017 10:16
01-26-2017 10:16
I dont have half of those options on mine either 😞
02-01-2017 03:19
02-01-2017 03:19
On my charge 2 I have a heart with the number 73 underneath but it also has a flashing circle of dots around it. Does anyone know what that means? Thank you
02-01-2017 03:47
02-01-2017 03:47
Hi, that is your heart rate. You can change your 'face' by going into your app and hitting the charge two symbol then it has a list- clock face is third down, swipe to see different options
04-06-2017 07:19
04-06-2017 07:19
The guy with the 250 is how many of the 250 step per hour goal you have taken. So, 30/250 means you have taken 30 out of the 250 steps in an hour. Also the Hourly Activity tile on your dashboard shows the number of hours you met your goal so far today.
05-03-2017 13:22
05-03-2017 13:22
The man running with numbers under it is how many times you have exercised within that week
08-09-2017 02:36
08-09-2017 02:36
Hi. With regards to the flame symbol and how many calories you have burnt, do you know if you can change the display unit on the band to calories instead of kj?
09-07-2017 10:46
09-07-2017 10:46
Due to neuropathy caused by five back surgeries, I have difficulty walking, BUT, I can ride a bicycle! I wish there were an app for that. (Hey, that would be a great line in a country song!) Don't go stealing that now because my grandson is a song writer, and I'm giving that sentence to him>
09-16-2017 18:26
09-16-2017 18:26
Mapmyride or Strava both track bicycling @fchammer1
