12-28-2016
23:25
14:34
AlessFitbit
12-28-2016
23:25
14:34
AlessFitbit
Hi Everyone,
As I flip through my watch, I see some symbols that I do not know the meaning of... is there a photo of the symbols that tell me the meaning i.e a guide that I can refernce ?
Like what is the flame with a number under it?
or the lighting bolt? or the man with his leg bent and arms up?
Christina
Moderator edit: format and title for clarity
05-24-2018 12:59
05-24-2018 12:59
05-29-2018 05:35
05-29-2018 05:35
She was just asking a question... you are rude
Best Answer05-29-2018 09:15
05-29-2018 09:15
You have probably found out by now but, for anyone else who has the same question, the 250/250 means that you have completed 250 steps of your hourly 250 steps minimum. You the time range when you want to be reminded and the tracker will buzz (if you have notifications turned on) if you haven't taken 250 steps in that particular hour.
Best Answer05-29-2018 18:17 - edited 05-29-2018 18:18
Charge 2 has bike. treadmill and weights option
Best Answer05-29-2018 22:46
05-29-2018 22:46
Actually @Shopkins72 the Charge 2 has 19 different exercises of which 7 may be loaded.
06-15-2018 10:54
06-15-2018 10:54
Is there one for battery
Best Answer06-15-2018 12:17
06-15-2018 12:17
You can add a battery menu item to the charge 2 .The battery will then be on its own page .
Let's go to Fitbit help
How do I customize the menus on my Charge 2?
07-02-2018 05:39
07-02-2018 05:39
Christina89,
Thank you for your assistance.
Fern1969
Best Answer07-02-2018 05:42
07-02-2018 05:42
Best Answer09-11-2018 13:50
09-11-2018 13:50
OK
So I don't have all the icons either, but with the 2 shoes, it shows a K. What is that? Kilometers?
and the comma with the dot inside of it, shows Ml or Mi... what is that for?
The flame shows 1.3 K, what is the K ?
Thanks.
Best Answer12-29-2018 18:48
12-29-2018 18:48
I don’t think so
Best Answer12-29-2018 20:01
12-29-2018 20:01
@threeholein1s add a screen shot so we know what your asking about?
12-30-2018 15:28
12-30-2018 15:28
the heart is your pulse rate. I don't know what the circle with dots is either. I found a page with all the symbols explained except that circle.
Best Answer12-31-2018 09:13
12-31-2018 09:13
Opening the Fitbit app you will notice the same symbols on the dashboard, however there symbols also have a description under them such as Steps, Floors,Calories, etc
The circle with three dots will be similar to the active hour tile below. The dots represent the hours that had an least 250 steps in them.
12-31-2018 10:07
12-31-2018 10:07
01-04-2019 11:24
01-04-2019 11:24
Found it...... was puzzled like others
Thx
01-23-2019 03:23
01-23-2019 03:23
Thanks. Problem solved but I also would like how to convert calories to kj.j
Best Answer01-23-2019 03:57
01-23-2019 03:57
It doesn't look too hard to convert, a simple Google.
01-23-2019 07:22
01-23-2019 07:22
Many thanks for conversion info.
Best Answer01-24-2019 12:21
01-24-2019 12:21
I still can't find it!!!!!!
